No More LQ9's
Old Jul 19, 2007 | 03:08 PM
GMC_DUDE's Avatar
Default No More LQ9's
Ordered the 6.0L from Scoggin-Dickey today. Found out GM has discontinued manufacturing the LQ9's, even as crate motors. Had to settle for an LQ4.
Old Jul 19, 2007 | 03:23 PM
Tootall's Avatar
uhhaaaa . . . . you can order your own pistons else where.
Old Jul 19, 2007 | 03:25 PM
ZZebes's Avatar
that sucks, order an LS2 and put a truck intake
Old Jul 20, 2007 | 01:01 PM
SGT637's Avatar
That is interesting. The LQ9 crate is listed in the new GM performance parts catalog that just came out. I guess us guys with LQ9 from the factory are stuck out if something goes boom. Buy the Lq4 and put Lq9 piston and rods in I suppose.
Old Jul 20, 2007 | 01:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
SHould have ordered an L92
Old Jul 20, 2007 | 02:14 PM
GMC_DUDE's Avatar
I would but it's a bit pricey, esp. since I also have to buy a new tranny . Plus I wanted something that was a drop-in without having to do much modding, and would work w/ the Radix. Oh well, the LQ4 should be an improvement over the 4.8, and with the Radix and a good tune, prob not much different from the LQ9.
Old Jul 20, 2007 | 04:04 PM
KevinF56's Avatar
wouldnt you rather have an LQ4 for a radix because of the lower compression ratio?
Old Jul 21, 2007 | 11:32 AM
Red04Silverado's Avatar
Can you still buy the LQ9 block from SDPC???? I just wanted the block to start my build
Old Jul 21, 2007 | 11:44 AM
2002C5COUPE's Avatar
the blocks are the same as the LQ4's
Old Jul 21, 2007 | 11:50 AM
2004SSS's Avatar
not imo , the 112 cant produce enough boost on a 6.0 to where the compression ratio will hurt performance. if you have goals to go bigger than yes an lq4 would be a better choice.
