No freakin ac??
Old Aug 26, 2009 | 09:49 PM
budhayes3's Avatar
PT's Slowest Truck
If it's full of refrigerant and the compressor still isn't coming on, you may have a bad pressure switch
Old Aug 27, 2009 | 07:12 AM
Coban's Avatar
Originally Posted by thunder550
Damn you. I need to keep checking threads when I make comments like that.
Plus, I have a high-fiber diet
Old Aug 28, 2009 | 10:56 AM
dhpro's Avatar
Originally Posted by AKlowriderZ71
When my a/c quit, I found that I had thrown off the a/c belt. Easy fix.
Why wud a guy in AK need AC? Free up the HP and leave the belt off!
Old Aug 28, 2009 | 10:59 AM
dhpro's Avatar
Originally Posted by BlackLM7
I remember some people here resolving their A/C problems by disconnecting the negative on the battery for about a minute and connecting it up again. Worth a try I guess....
If ur AC was off for a long while this fix sometimes works, as thats usually caused by stuck accumulator doors. yours sounds more like pressure switch to me. I had my head unit replaced, but from what GM tells me, thats rarely the prob. R/
Old Aug 28, 2009 | 02:45 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It gets hot up here sometimes. Hard to deal with these 70 degree temps in the summer.
Old Aug 29, 2009 | 12:15 AM
branndonw's Avatar
Could be a bad clutch coil. Unplug the AC compressor clutch coil connector. On the compressor side, connect 12v to one pin and then touch the other to ground. Your clutch should engage. If not you need a new coil.
Old Aug 31, 2009 | 04:28 PM
ino
I have the same exact problem as you. Was working fine and it stopped will check that relay test you did and other test on here also.
GMC5.3
13
Aug 10, 2005 01:56 PM
slow99
Jun 29, 2005 12:41 PM
Onyx 02
27
May 7, 2005 02:38 PM
Black-Syde
Mar 17, 2005 07:48 PM
KeukaZ71
Feb 25, 2004 10:31 PM
