No brake lights
Old Oct 15, 2019 | 09:52 PM
_zebra's Avatar
makes children cry
a tilt switch? like the underhood light (that rarely works)?
i figured it'd be a plunger considering how quick it normally engaged.
but normally open makes sense for a 20yr old circuit, rather than it telling some nanny computer one thing so the computer can actuate something else kind of bullcrap.
Old Oct 15, 2019 | 09:58 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Try this. I'm on my phone. It's the first thing I found that I could view.
I would have to take the old one apart to show you and I am far to lazy right now...
Old Oct 15, 2019 | 10:42 PM
_zebra's Avatar
makes children cry
glad i had my hand-dandy RPO decoder on the desktop (from looking at trucks for my wife)
here i was guessing JF4 was cruise... wrong! it's power pedals (neither of which i have anyway).
is this chart for a 99-02 or 03+? my plug has (A -> D) white, orange, purple, brown (last 2 swapped). does that even matter?
as for the switch, i opened it up & it's a spring loaded set of contacts (one normal-open, two normal-closed), so i'll just measure continuity across each pin pair.
i always forget i have a camera at home. forgive the mess... this is probably the first time in 20yrs it's been off the pedal.
Old Oct 15, 2019 | 10:58 PM
1FastBrick's Avatar
That was a 2003 I believe. I haven't found one for a 99-02 truck but I believe it's the same. Just different colors.
Of course now that I say that I will definitely be wrong!
Yes, you have the right idea checking continuity
Old Oct 15, 2019 | 11:10 PM
_zebra's Avatar
makes children cry
hmm... took it all apart & the contacts are clean, good continuity when it's supposed to, open when it's supposed to.
reckon, based on that chart, i'll just put on a rubber glove & stick a paperclip across pins A & B of the connector to see if the lights come on...
Old Oct 15, 2019 | 11:47 PM
_zebra's Avatar
makes children cry
dangit... i'm gettin' old & sloppy.
switch tested good on every iteration. solid 12.4v on orange. used the paperclip jumper with no success - even with 12.4v on the jumper.
plugged the switch back in & used a screwdriver to push the plunger... got a flicker as i moved my hand around. noticed the dang white wire has a brittle/broken spot on the jacket & it's starting to fray.
electronics 101: see if it even looks right before you start tearing crap apart!
reckon i'll drive the car tomorrow & butt splice it after work... just like i did with the dome light after a couple years of intermittently trying to figure it out.
Old Oct 15, 2019 | 11:48 PM
1FastBrick's Avatar
These things happen...
Old Oct 15, 2019 | 11:50 PM
_zebra's Avatar
makes children cry
thanks for the data & help, though. you're a real pal
Old Oct 16, 2019 | 12:02 AM
1FastBrick's Avatar
I tried. Even when I was wrong...
GMCtrk
Jun 9, 2014 09:21 PM
Silverado256
May 14, 2012 12:10 AM
gm50cal
Mar 8, 2010 11:20 AM
GOT LS1
Oct 7, 2008 12:32 AM
KeukaZ71
Jun 19, 2003 09:24 PM
