need help!!! hard time pumping gas into truck
Old Jul 22, 2010 | 12:05 PM
slowswb's Avatar
Default need help!!! hard time pumping gas into truck
i have 04 Chevy silverado 1500 with 5.3. the problem has been getting worse now it wont let pump gas it stop like ever 2 dollars. when i open my gas cap before fueling up it sounds like alot of air is coming out or sucking in. the truck isnt throwing any codes either.
Old Jul 22, 2010 | 02:58 PM
skoal bandit's Avatar
That was happening on mine a year ago. I had something plugged and warranty replaced it. Just can't think of what it was. Had something to do with the gas tank vent or something.
Old Jul 22, 2010 | 04:27 PM
Uncle Monkey's Avatar
Sounds like a plug beather line on the fuel tank. Check your warranty. It should be covered under emissions/pollution control which have a much longer warranty then bumper to bumper.
If not check the small line that runs beside the larger fill hose.
Old Jul 22, 2010 | 05:54 PM
slowswb's Avatar
the truck has a 100k on i dont think it has anymore warranty. ill check it out im going to try to replace that small line.
Old Jul 22, 2010 | 08:24 PM
TIM Z's Avatar
11 sec. Truck Mod
Its the evap solenoid ( or whatever its called) that is mounted on the tank itself.
My 05 tahoe did the same thing, about 22$ from the dealer, easy fix.
Old Jul 22, 2010 | 10:19 PM
WHITE5.3L's Avatar
mine does this every once in awhile too its very annoying!
Old Jul 23, 2010 | 11:10 AM
Coban's Avatar
I just pull the nozzle out a little bit at a time till it starts working.
Old Jul 26, 2010 | 06:48 PM
slowswb's Avatar
yeah that doesnt work
Old Jul 27, 2010 | 02:17 AM
SilverDog's Avatar
My votes on the tank vent solenoid.
Edit: Found an old post that should help. Sounds like 04BlackSilverado was having the same problem.
https://www.performancetrucks.net/fo...d.php?t=368161
Old Jul 27, 2010 | 10:09 AM
fastnblu's Avatar
I just started havin this same problem. It's absolutely annoying the **** outta me!!!
