need help with 80e swap
Old May 14, 2010 | 09:13 PM
SmokinHot98's Avatar
Default need help with 80e swap
I have pretty much everything for the swap here or on the way, but I'm stuck at the trans lines. I don't want to extend them, but I heard the suburban lines work. Is that true? If so what is the part number of the line? Also where can I get the transgo shift kit and vette servo for the trans? Can you post a link, I've loooked but failed
Thanks
Old May 15, 2010 | 10:50 AM
Im sure the suburban lines will work or one from a 2500 truck, its the line in the rear of the trans. make sure to get a trans cooler i used lines from a 2500 truck ans still need to be modified up front for the trans cooler.
Old May 15, 2010 | 03:56 PM
cool, could you post a pic or send me a pic of how you did it?
Old May 15, 2010 | 04:13 PM
if anyone else has some info or links that would be great
Old May 15, 2010 | 08:15 PM
brent5631's Avatar
Everything you need to know in here.
https://www.performancetrucks.net/fo...d.php?t=424904
Old May 15, 2010 | 08:23 PM
brent1976's Avatar
11 Second Club
I used the part numbers from kysilverado write up, lined up perfectly for my trans cooler.
Old May 16, 2010 | 12:08 AM
brent5631's Avatar
The ones from KY's thread only work 100% if you have a factory cooler. But i just cut them and bypassed the rad anyway.
Old May 16, 2010 | 12:26 AM
i'm going to maintain the factory cooler for now
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
alex226
Jul 16, 2015 10:55 AM
JordanH
Jul 14, 2015 03:46 PM
