Need help with 5.3 in an 04 Tahoe
Old Oct 5, 2012 | 03:38 PM
lsvega-s's Avatar
Default Need help with 5.3 in an 04 Tahoe
I have an 04 Tahoe that my wife drives. It has two lifters that I believe are collapsed. It is ticking really loud and running rough. I pulled the valve covers and one on each side is getting no oil up the push rod. I have the heads off now and was going to change the lifters.
When I got the lifters out the rollers are completely surrounded by the lifter body not held by the ears like on the others I have dealt with. did they change lifter designs some time or have these been changed some time? Can I use the other style lifter or is the geometry wrong? I have a set that is nearly new and would like to use them if I can.
Thank you for the help. I will try to get some pictures up if they will help.
Old Oct 5, 2012 | 03:59 PM
nonnieselman's Avatar
Pics or part numbers will be helpful.
Old Oct 5, 2012 | 05:47 PM
lsvega-s's Avatar
Here are a few pictures.
The ones in the truck
This is the extra set I have.
Old Oct 5, 2012 | 08:12 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The fully encapsulated ones are the better ones. I would get another set my self.
The used ones don't look very good. They may be dirty but it looks like 1 or 2 rollers have some heavy wear marks on them.
Old Oct 5, 2012 | 09:37 PM
lsvega-s's Avatar
Thank you for the reply. I think the other ones are just dirty in the pics. I used my phone to get a couple quick shots of each. I will probly just get some new ones just didn't know they switched styles.
What is the difference in the LS7 lifters I see a lot of people switching too? I have read they are a different height so you have to get different push rods. Is this correct?
Again thank you for the info I am still trying to learn about these engines and what parts will interchange with each other.
Old Oct 5, 2012 | 10:33 PM
1FastBrick's Avatar
There is none. That is basically what you took out.
GM part number 12499225 is a pack of 16
The Individual GM part number is 17122490 for 1 lifter
Old Oct 6, 2012 | 03:19 PM
lsvega-s's Avatar
Thank you very much. I really appreciate the part numbers too.
Old Oct 7, 2012 | 02:17 AM
1FastBrick's Avatar
You're welcome!!! If you need some more you can look here
https://www.performancetrucks.net/fo...umbers-428941/
Zizzle
Oct 19, 2017 08:44 PM
JordanH
Aug 8, 2015 07:59 PM
brandon6.0
Aug 7, 2015 11:22 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
