need to clean my fuel injectors
DOH
I realized what I said when you said vacuum port. You are absolutely right, Sea Foam in the vacuum line won't do anything for the injector, except maybe smudge what's on the bottom. I say back to the first idea ... Sea Foam in a half tank of gas, 2 cans if you think it's that bad.
Originally Posted by Flyer
Sea Foam ... I used a whole can in a half a tank of gas. Worked well.
Others have poured it directly into a vacuum line and let the engine suck it in that way. I hear that you should change the oil after doing it that way though.
i think somoene said not to pour it into the gas tank? is it safe?
Originally Posted by rgvsierra
has anyone else put seafoam in the gastank?
Originally Posted by silent1
All that stuff does is "tickle" any kind of build up on the injectors. What is used at the dealers runs directly in the fuel lines and the fuel pump is disabled. It usually takes about 20-30 minutes.
hurray for nitrogen blasts through the injectors
rojeho
08-08-2015 07:20 PM
