need advice blowing white smoke out exhaust after brake change
Old Nov 5, 2012 | 07:48 AM
bluebommer07's Avatar
i have the 862s lol
Old Nov 5, 2012 | 12:24 PM
wheeliE-maxx's Avatar
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
my c10 leaked fluid into the booster from the master cylinder. Not enough to smoke. Wouldn't explain your oil loss though.
Old Nov 5, 2012 | 12:46 PM
since last night i pulled tb and looked in intake. An I see oil rolling around in bottom . Think once I got truck in air to change brakes and started it oil got sucked into the intake on both sides and that's where the smoke was coming from .. I'm going to change plugs AnD go from there
Old Nov 9, 2012 | 11:11 AM
Junkyard Dog's Avatar
Does it smoke all the time, or just for a little bit at start up? In other words, if you drive down the road for two miles, is it still smoking, or does it stop until you shut it off and start it again?
If so, check out my last few posts, as I have a thread on this issue with a simple solution that has worked twice now a year apart.
Old Sep 29, 2013 | 04:04 PM
S2K Matt's Avatar
I know this an old thread, and I apologize for opening it up again, but I just did a brake job on my silverado also and jacked it up by the frame rails. I have done brakes many times before but never jacked from the rail as you described also. Now my truck is blowing smoke like you described, and lots of it.
What was the resolution to this issue? Im hoping and assuming just the aggressive angle of jacking it up by the frame caused fluid to flow into the motor somewhere making it smoke? I am hesitating to start my truck again in fear of damaging something worse, but im guessing it will just burn up and go away?
Thanks
Old Oct 29, 2013 | 07:31 PM
LS1TRUCKGUY's Avatar
Thanks
pull the throttlebody off and look in the intake to see if there is a bunch of oil pooled up in there. if thats the case, yes, the oil will burn off and you should be fine. it might foul the spark plugs and maybe the o2 sensors.
check your pcv valve on the back of the valve cover by the firewall. it is probably sucking up a bunch of oil and putting straight into your intake.
Old Oct 29, 2013 | 07:32 PM
just realized this was posted a month ago
ARC
57
Feb 21, 2022 10:54 AM
thewrx
Aug 12, 2015 08:28 PM
atxlt
Jul 20, 2015 11:06 PM
rojeho
Jul 12, 2015 06:10 PM
08DenaliT
Jul 8, 2015 09:13 PM
