My truck pukes fuel at the pump!!!!!
Old Mar 28, 2007 | 12:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default My truck pukes fuel at the pump!!!!!
It's done it a couple times now... when I fill it up. it wont automatically click off it just starts running on the ground!!!!!!! what do I need to check to see what the problem is??? I just filled it up Yesterday morning and it did it again probably $4 on the ground under it it cost me over $60 to fill it up, and I dont want to pump the expensive **** on the ground.... gas is on the rise again here
Old Mar 28, 2007 | 01:40 PM
kawamatt2's Avatar
You sure your inserting the pump completely into the filler neck as far as it will go. I sometimes find with certain pumps that they will prematurely click off if i try to give it the full flow so i pull the spout out just about an inch or a half inch to keep it from clicking off. I think the auto click off function of most pumps works on the principal that if any fuel splashes back or comes back up the nozzle they click off. I drive an obs and i think the way the filler neck must be routed is sometimes causes fuel to splash back triggering the pump to click off.
I really don't see how your truck could be the problem. Unless you have physically changed the filler neck routing or something.
Old Mar 28, 2007 | 01:51 PM
KevinF56's Avatar
it's the pump that is doing that. i used to work at a gas station and that would happen sometimes. it usually happened when you had a car that would keep clicking off. some of them just do. ford explorers for example suck. you have to pull the pump almost all the way out and put it on super slow. that combination (pump barely in the filler neck and pumping slowly) usually was the reason for the pump not shutting off.
Old Mar 28, 2007 | 02:05 PM
chevyboy90's Avatar
how long has it been doing that since u got it, or barely
Old Mar 28, 2007 | 02:06 PM
ZR1 DREAMING's Avatar
Damn Ben! You got enough money to pour on pavement but you can't pay me back yet? WTF?!
Old Mar 28, 2007 | 02:13 PM
CHEVRACER83's Avatar
The Pumps Have A Venturi Like A Carburetor... And When It Senses The Difference Of Pressure That Goes By It As The Tank Gets Fuller (i Made A New Word!!) It Will Cut Off.... Thats Why If Your Tank Doesnt Vent Well It Will Cut Off
Old Mar 28, 2007 | 02:41 PM
Hunt&Fisherator
Its done it at a few different gas stations… so I'm thinking its something to do with the tank… I guess I'll take the bed off and give it a look… the maybe a pinched vent hose?? Its not running from the filler hole… its coming out under the truck like maybe where the filler meets the tank itself??? I don’t know…
Old Mar 28, 2007 | 03:02 PM
Yeah Theres A Clamp Under There And If You Changed The Pump And For Got About It... Or Didnt Realize And The Hose Has A Small Split It Will Do That Once Full
Old Mar 28, 2007 | 03:06 PM
Hunt&Fisherator
I'll check it out… I have changed the pump but that was a good while back and it just started doing it the past couple weeks… I guess investigating it will be the only way to fix it…
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
GMCtrk
Jul 17, 2015 06:39 PM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
