Mounting Trans Coolers
Old Aug 22, 2002 | 10:26 AM
CashDudeHomie's Avatar
Default Mounting Trans Coolers
I need some of those things that you poke thru the radiator and snap the end on like that come with the transmission cooler. Oxidizr didn't you make some custom brackets for your Hayden and did you throw these away or do you still have them? If anyone has some of these and wants to sell them just post how much you want for them. Thanks for your help.
EDIT 8-24-02 - POST PICS OF YOUR TRANS COOLERS (if you have any pics.) Thanks.
<small>[ August 24, 2002, 02:19 AM: Message edited by: CashDudeHomie ]</small>
Old Aug 22, 2002 | 11:49 AM
GREGGO's Avatar
Default Re: Mounting Trans Coolers
look here.... if no-one else has them for you.Hayden
Greg
Old Aug 22, 2002 | 01:05 PM
Ryan23silverado's Avatar
You can pick these up at an autoparts store. I got some at Checker out here. (it might be a Kragen or Shucks out there) or try an AutoZone.
Old Aug 22, 2002 | 01:33 PM
Thanks Ryan and Greg for the info.
Old Aug 23, 2002 | 01:50 AM
They were in stock at Oreilly's $4.50. I used 1 to fix my transmission cooler, and since I had everything apart, I used the other 3 to hold my LS1 fans to the radiator, and tossed the ghetto bed brackets I had on there.
Old Aug 23, 2002 | 01:19 PM
graygmc's Avatar
you dont even need those things. i just used the factory brackets for the tranny cooler and used self-tapping screws to hold it in place.
Old Aug 24, 2002 | 12:32 AM
Are you saying you have only one of the plastic ties holding your tranny cooler in place? At that price, you may just want to buy another set of them and make sure your fans and coolers are secured really well. The plastic ties are sometimes known to break.
Old Aug 24, 2002 | 02:03 AM
HAHA Ryan sorry I forgot to mention I already had 3 on there when I bought the new set of 4. The reason why is I had mounted it thru the AC condenser and the radiator, and I decided I didn't want to put so much stress on the ties, so I cut them and put them just thru the AC condenser. Well they aren't made to be reused but I got 3 of them to work, on the 4th one, the ring that snaps on broke. Graygmc, I don't know what you mean, mine didn't come with any brackets, it didn't even come with an aux transmission cooler, just a line going thru the side of the radiator. What did you screw the brackets to and where did you mount the cooler? How big is your cooler? Do you have any pics? Thanks dudes. <img src="http://images.prosperpoint.com/images/2205/111281-19.jpg" alt=" - " />
<small>[ August 24, 2002, 02:13 AM: Message edited by: CashDudeHomie ]</small>
Old Aug 24, 2002 | 07:32 PM
GREGGO's Avatar
Here is mine... <img src="http://home.swbell.net/greghud/tracool04.jpg" alt=" - " />
Old Aug 24, 2002 | 09:59 PM
oxidizr's Avatar
Moderator / Sponsor
I hate those things (zip retainers.) They are probably not too bad for supporting a cooler but I would caution you on mounting the fan with them. The fan has harmonics and vibrations which will be directly tranmistted to the radiatior core. Too much and you can damage the core tubes. Check with any reputable radiator rebuild shop and they will concur that these things are not good for aux or primary Fan mounting.
Richard
GRRR65GTO
Aug 17, 2015 11:33 PM
1slwgto
Aug 16, 2015 06:40 PM
zaathur151
Aug 12, 2015 06:32 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
