Motor swap starting tonight
Old Jan 9, 2004 | 05:15 PM
Scream's Avatar
MOOBIES Moderator
Default Motor swap starting tonight
Everyone wish me luck...the LS1 swap is starting right now. We're going to try to have everything ready to pull the motor out first thing in the morning.
I CAN'T WAIT! I'll be sure to let everyone know how the first drive goes! Wish me luck!
Old Jan 9, 2004 | 05:35 PM
FILE's Avatar
Good luck man... what are you going the with the cam you have in your 4.8?
Old Jan 9, 2004 | 05:53 PM
Scream's Avatar
MOOBIES Moderator
I have a couple of people locally that might get it. If not, I'll post it in the truck classifieds!
Old Jan 9, 2004 | 06:09 PM
Scream's Avatar
MOOBIES Moderator
BEFORE--Ground to bottom of fender opening:
DS: 27.75
PS: 28.25
AFTER ??
Old Jan 9, 2004 | 06:55 PM
03Screamer's Avatar
On a scale of 1-10, 10 being the most difficult, what would you rate a 4.8 to 6.0 liter swap like you're doing? I'd Imagine it's probably pretty easy, am I right? When I get a 6.0, I'm thinking of just doing the swap on a weekend with a friend, so I don't have to pay a shop hundreds $$$. Thanks
Old Jan 9, 2004 | 09:33 PM
Texas Terminator's Avatar
11 Second Club
just take off all of the accessories and it will drop right in!! keep us posted!!
Old Jan 10, 2004 | 11:30 AM
graygmc's Avatar
yeah just take off the accessories and about 50 plugs for sensors and what not and your set to go.
scream hope the install goes well.
Old Jan 10, 2004 | 02:36 PM
03Screamer's Avatar
The swap sounds easy enough...thanks guys.
Old Jan 10, 2004 | 03:14 PM
1TRUESS's Avatar
Good Luck! Are you planing on taking any pics?
Old Jan 11, 2004 | 12:01 PM
Scream's Avatar
MOOBIES Moderator
Had a little difficulty with the flexplate-to-torque convertor bolts, but other than that, the longblock is in the truck. getting ready to finish the swap today (intake/exhaust manifolds, wiring, etc.)
Couple of things that I noticed:
1) The A/C bracket has one extra bolt hole that doesn't have a boss on the aluminum block. I think that 4 out of 5 is sufficient!
2) If you decide to use ARP main studs and the truck oil pan, you need two more nuts/washers to fully attach the truck windage tray. The car tray has 8 bolts, and the truck has 10.
3) It looks like the truck has lifted about an inch or so with the aluminum block in there. I'm going to measure it again when we get some weight back on it and I drive it for a while.
There's nothing about this swap that seems too difficult. There are a LOT of wires and a LOT of bolts!
