ls swap on 96 silverado
Well guys time has came to pull out the 350 and replace it with a 08 4.8 but I have a couple of ?? What motor mounts are yall running I been looking at the trans dapt 4592 will these work or is the other ones without be adjustable. .dont see the point in being adjustable also I plan on keeping the factory gauges working any special type of harness I need I was able to get the 4.8 with trans and harness, pcm and pedal for $800 so far these are the questions I have as of now but im sure I will need yalls help down the road
I'm swapping a 6.0 in my 97 now, and I am using dirty ding motor mounts. You can repin your factory harness to the new 411 computer and just add 10 wires for the coils and another for the knock sensors. Also you will need to cut your one big injector plug off and add the 8 injector plug ins. You can still use the drive by cable factor throttle body if you want to also. It's not beat as hard as it sounds, pm lextech if you want more info on the wiring.
Here is what I did.
Read this over and over again:
OBS to LSx conversion
Then read the pages in this that correspond to your year donor harness:
Wiring Harness Information
Then read every thread you can possibly find on swaps. Google helps with this. I can share my bookmarks, but I can't from the machine I am on now. PM me tomorrow or late tonight to remind me and I'll post a link to them here.
Finally figured out how to copy a lot of links at once. These may not all be applicable to you, but I am posting everything I have even remotely related to doing the engine swap.
Engine/Efans/Wiring/Mounts/Exhaust Links:
LSX oil pans - LS1TECH
LS1 Oil Pan with Different Oil Filter Adapter - LS1TECH
Tach wiring for 99+ Vortec/LS1
http://i2.photobucket.com/albums/y28...5FanWiring.jpg
ImageShack® - Online Photo and Video Hosting
steam vent routing.
PSI // Performance Systems Integration // 732.691.6531
https://www.performancetrucks.net/fo...shrods-505622/
LS1TECH - View Single Post - correct pushrod length
LSx conversion swap mounts, LS conversion brackets and LS1 swap plates. - LS1 R4 AC Install - LS1 R4 AC Install
Exhaust
How To Calculate Muffler Size and Exhaust Pipe Diameter | Exhaust Videos
LS1Truck.com
LS1TECH - View Single Post - Cam for L92 Heads: Lessons Learned
portland area machine shop? - LS1TECH
Machine shops for LS rebuild? - Corvette Forum
COMP Rocker Trunion Install - Page 2 - Corvette Forum
GM Performance :: View topic - 130 mph dash ??
1990 obs speedo connection
3 wire ECT diagram
Three wire coolant sensor wiring?
Budget Pressure Luber Build Photo 12
Auto Exhaust Science
How to Install a Comp Cam in a 5.3L LM7 Part 2 - YouTube
95 wiring removal
http://www.summitracing.com/parts/edl-3864
Hydroboost intake fitting
OBS evap canister
https://www.performancetrucks.net/fo...3/#post4711055
Fuel Pressure Explained | Injector Dynamics
How to install aftermarket and stock gauge gauges 3 wire coolant temperature sensor and sender ls1 - YouTube
Math to figure out if your car will run on pump gas. - LS1TECH
A/C Links:
Josh Power's AC bracket - Page 2
• View topic - A/C Summary
Air Conditioning Compressor Relocation - Novak Conversions
http://customimagecorvettes.com/stor...cessories.html
Air conditioner signal integration
Stock R4 compressor MOD and E-fan hook up HOW TO
Alternative A/C mounting Using S10 Compressor - The 1947 - Present Chevrolet & GMC Truck Message Board Network
NNBS/TBSS Intake Swap Links:
https://www.performancetrucks.net/fo...-today-500762/
TBSS intake install on NBS - PerformanceTrucks.net Forums
"how-to" 03-07c NBS TBSS/NNBS intake swap - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
Head/Cam Swap Links:
LS1Howto.com
steam vent routing.
Exhaust
LS1Truck.com
3 wire ECT diagram
95 wiring removal
OBS evap canister
A/C Links:
LS1Howto.com
oharajo
Jul 18, 2015 09:24 PM
mrgrim
Jul 8, 2015 08:12 AM
