LQ4 Throttle By Wire conversion
Old 01-02-2009, 10:11 AM
  #21
kbracing96's Avatar
Originally Posted by Wilde Racing
I just remembered, G.M changed the PCM plugs in 03 to you would have to convert your harness, or as KB said find a bin file from a a GTO... I think it woulld be wise for you to look into to tuning software. a conversion like that would be made much easier if you could turn on/off codes and flash files....
You need more then just the BIN from the 04 GTO PCM, you have to have that PCM, (it's a different service number then the rest of the 1 meg PCM's). As for the harness, that shouldn't be to hard, might need to change a few pins around and you can buy the red pin retainer from here so it will plug into a 99-02 pcm.
http://www.eficonnection.com/eficonnection/100w.aspx
Old 01-02-2009, 06:34 PM
  #22
jsburkey21's Avatar
OK, today i made out like a bandit.
I picked up a 2004 model 6.0 complete with every accessory, wiring harness, 2 computers, 2 throttle bodies, all the sensors, and even the covers for $1300. The motor has 35,000 miles on it and is in excellent condition.
I found a 2001 2500 with a cable style throttle body and the computer to match it.
Here are 3 pics of the motor.
Old 01-02-2009, 06:36 PM
  #23
jsburkey21's Avatar
The computers i picked up are from a 2004 2500 and a 2001 2500.
Old 01-02-2009, 06:44 PM
  #24
jsburkey21's Avatar
This may help someone out with the installation of the cable throttle body on their FBW (Fly By Wire) truck.
The throttle bodies do not just "swap" on. Some modifications had to be made for mine to fit.
The 2004 model CCV (crank case ventilation) hose hooks up on the intake manifold while the 2001 model CCV hose hooks up on the throttle body. The throttle body will not bolt on because the 2 hit eachother. Here is a picture.
Luckly the CCV tube on the cable throttle body can be easily removed and discarded leaving a nice hole that can be easily tapped by a 1/8 NPT pipe thread tap and plugged off.
Old 01-02-2009, 06:51 PM
  #25
jsburkey21's Avatar
Does anyone know of a good place for me to send my wiring harness to have it cut down?
I have seen places in the internet that will take a factory wiring harness and cut all the unnecessary emmissions loops out along with anything that does not directly effect the running of the motor. They then ship the harness back to you with one hot to the battery, one keyed ignition hot, and a main ground for an easy installation.
Old 01-11-2009, 03:35 PM
  #26
droppedchev's Avatar
im having a little problem with pcm to i have a 00 4.8 that im swaping to a 01 5.3 and my buddy has hp tuners and he has 03,04,05,06 can i take a 03 pcm that is a drive by wire program it to a drive by cable will the hp tuners be able to do that or no
Old 01-11-2009, 08:42 PM
  #27
kbracing96's Avatar
Nope, 03+ are 1 meg pcm's and 99-02 are 512kbs. Not compatibly pcms or tune files
Oobray
06-13-2022 03:38 AM
smokeshow
08-23-2015 08:23 PM
Fast86z
08-23-2015 12:35 AM
Ammadien
07-22-2015 08:50 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: LQ4 Throttle By Wire conversion
