LQ4 oil leak
Old Oct 11, 2013 | 03:56 PM
SSpeeDEMONSS's Avatar
Default LQ4 oil leak
truck is nearing 200k and has been problem free the entire time. recently it has started to leak oil. i got under it today to take a look and am not sure what is leaking.
looks like right here.
right here to be exact
from farther back
what is that that looks like it is leaking? is that just a simple gasket?
Garrett
Old Oct 11, 2013 | 03:58 PM
BlackGMC's Avatar
Resident Retard
Check higher up. Mine was leaking at the valve cover gasket and leaked down exactly like that.
Old Oct 11, 2013 | 04:07 PM
valve cover looked good. dry. only seems to leave a drop or two where i park but i just changed the oil on the 28th and my low oil light just came on last night.
Garrett
Old Oct 11, 2013 | 04:21 PM
Bit's Avatar
Bit
That is the oil cooler adapter. If you had an oil cooler there would be lines going to the radiator. Its a gasket in there that is leaking. Easy fix.
Old Oct 11, 2013 | 04:25 PM
is it just pressurized when running? i wont lose a lot by changing the gasket?
Garrett
Old Oct 11, 2013 | 04:40 PM
Bit's Avatar
Bit
You will loose a little when u unbolt it. Just clean both surfaces good and refill oil level.
Old Oct 11, 2013 | 11:16 PM
Suburbazine's Avatar
Garrett
It's got full pump pressure when running and you will lose a little bit when you take it off, all the oil will fall from the passages above so it will make a mess if you're not careful.
Old Oct 12, 2013 | 12:10 AM
kbkiller's Avatar
change that gasket next time you change your oil. The only be a little oil in the oil cooling lines. Easy fix
Old Oct 12, 2013 | 06:19 AM
TIM Z's Avatar
11 sec. Truck Mod
It's above your oil pan , your hardly going to lose any oil unless you change while it's running
Old Oct 12, 2013 | 09:03 AM
livefast1's Avatar
If the adapter gasket doesn't fix it its probably the oil pan gasket. There are two pressurized ports integral to the oil pan that feed and return oil from the oil filter. I've seen these leak before.
