low coolant light comes on
Old Nov 10, 2007 | 10:29 AM
Phatchevy's Avatar
Default low coolant light comes on
very seldom (maybe 1 or 2 times a month) this happens but my LOW COOLANT light comes on and i've looked at the resevoir and it's normal. any idea what is causing this? it's been a long time since i've done a radiator flush (maybe 20,000 miles) anyways i've got about 131,000 miles now and i'm worrying about crap starting to break.
Old Nov 10, 2007 | 11:26 AM
krambo's Avatar
Well it could be alot of things however I had a 99 5.3L and the coolant sensor crapped out at about 45K. I say with 130k+ you did good. My SSS has 40K and the sensor tells me all the time it low From what I understand, it is a common issue. I would just check the coolant level, ensure there is no trapped air in the system and ignore the light after I verified that the sensor plug is o.k.
Old Nov 11, 2007 | 08:21 AM
I have never had that problem, but I was going to say the same thing. If you have coolant, then it really can't be much else.
Old Nov 11, 2007 | 01:49 PM
RandomHero's Avatar
do you have a cam? My truck gets the light every once in a while when I'm sitting at a stop idling for over 30 seconds or so. I think it's due to the cam and the idle set at 700
Old Nov 28, 2007 | 11:40 PM
Phatchevy's Avatar
i don't have a cam but now that you mention it my light i think does come on when sitting at a traffic light or something and then start moving. then i comes on and eventually goes away. i haven't had it come on in a coupe weeks. is it worth having the sensor changed out? can i do this or should i take it to the dealership?
Old Nov 28, 2007 | 11:58 PM
TexCrew's Avatar
my wifes tahoe has been doing that . she only has 70000 miles. i add a little coolant turn the truck on. the light goes out.
Bluchevypick
Aug 18, 2015 09:11 AM
TX Tahoe Z71
Aug 7, 2015 03:58 AM
Ketis
Jul 23, 2015 12:37 PM
ullose272
11
Jul 17, 2015 07:22 AM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
