A little ping!!
Old Feb 18, 2006 | 10:47 PM
5.3AlmnBlk's Avatar
Default A little ping!!
Im gettin a little ping when my engine goes to fourth gear when going up a slight little hill should i go up to 89? Try a octane booster? I have used the Outlaw octane booster and it made me pass my sticker in my aztek should i try it? I was gettin ping around town normal driving took the MAF screen out and it stoped but now i got it going up on slight hills.
Old Feb 18, 2006 | 11:07 PM
BlackLM7's Avatar
I would not use octane boosters unless you pour a bottle in every time you fill up the tank. I would try 89 in the next couple of tanks and see if it helps. Why did you take your MAF screen out? Descreened MAF's affect your truck's tune and it may contribute to unwanted performance like pinging.
Old Feb 19, 2006 | 07:32 AM
SnakeOiler's Avatar
Put in some 92 and it should go away.
Old Feb 19, 2006 | 03:13 PM
5.3AlmnBlk's Avatar
I was geting ping with the maf screen in so i said wth so i took the ring around the maf and took the screen out no more ping just when i get up slight hills. I also figured out today that i got a little hole in my muffler on the lip and its leaking water and it looks to be rusted would warranty cover this? if not me gettin a new one
Old Feb 19, 2006 | 04:07 PM
05GMCL33's Avatar
The hole in your muffler is there for a reson, that is to drain the condensation out of your exhaust system.
Old Feb 19, 2006 | 07:13 PM
5.3AlmnBlk's Avatar
Does air comeout of that hole? My friend has a 4.8 his muffler sounds like it has a hole could it be that one that got larger? Wonder what would happen if i made it a bit bigger.
Old Feb 19, 2006 | 07:43 PM
05GMCL33's Avatar
Leave it alone, your exhaust is stanless steel. Some exhaust might leak out but I would rather have a very small exhaust leak then water build up in my muffler.
Old Feb 19, 2006 | 08:08 PM
Post
How many miles are on your truck?
Try 92 or 93 oct fuel before trying an additive. Switch gas stations as well.
Exxon, Chevron, or Shell is what I would stick with. I use 93oct Shell 99% of the time.
If you take a look at the price increase from going from the 87 oct grade fuel to a 93 oct fuel, you will see that it is only $4.00 more on a complete fill up.
That's not much if you think about it.
Make sure your air filter is clean too.
Replace your MAF screen as well. It really hurts your performance without it. (nice power one day, and loss of power the next day).
I think doing this should solve your problem.
Jim
Old Feb 19, 2006 | 09:34 PM
5.3AlmnBlk's Avatar
Is there any way i can only buy the maf ends not the whole maf setup? I think i have may broken the ring a bit. I think ill stick without the screen and go to 89 if it dont work ill go to 93.
lucas287
31
Jan 12, 2021 06:18 AM
Tydriver
45
Oct 23, 2015 09:19 PM
Fast86z
Aug 23, 2015 12:35 AM
trever1t
Jan 5, 2006 04:46 PM
TwoFast
Jan 6, 2005 03:07 PM
