Jim Neuenfeldt is running!
#42
Yes thats right 33,000 volts!!! But only .14 milliamps just enough to almost break your arm. I use to work in a plastics plant and we had what we called edge pins to hold the plastic down on the metal cooling roll. Well if the pins got dusty or you happened to move them while the line was down you'd have to adjust them when you brought the line back up, usually w/ a pencil or plastic ball point pen. You could also grab ahold of the insulator (sp.) and rotate it or what have you to get it just right. Well one night I came in and the edge was alittle wavy so just after shift change I go back to adjust it and grab ahold of the insulator and WHAM!!! just like grabbing a lown mower spark plug w/ it running at full throttle!!! At shift change the next morning I wanted to kill the guy that knew about it but "forgot to tell me."
Zed
Sorry about that was at work and was trying to get outta there quick. I forgot to mention there was a hole in the insulator...Zed
Zed
#46
LS1TECH Sponsor
Jim Neuenfeldt is running! Get the Oct '04 issue of Hot Rod.
There is a full spread / write-up on Jim's truck with nice pics.
He even has Racetronix 57lb/hr injectors and one of our DP in-tank systems.
#47
check out this page >> http://www.neufamily.org/03html/fuelsystem.html
#48
LS1TECH Sponsor
Originally Posted by parish8
i pimp out you guys all the time, you should give me some free stuff
Mossyoakglock
Jul 17, 2015 08:30 AM
, and i dont feel bad about it at all.
