Intermittent lifter tick on 5.3??
Old Feb 16, 2018 | 07:57 PM
AZ414's Avatar
Registered User
Default Intermittent lifter tick on 5.3??
Hey y'all, kinda stumped on this one. i recently bought a 2007 classic RCSB with the L59 5.3 (flex-fuel) with 103K miles
well on day 2 of owning it i came to a red-light and thought i heard something, turned my radio down and yup.... tick tick tick... sounds exactly like a sticking lifter.
I have investigated some and it only happens when up to temp and low rpm. stop and go traffic is almost a sure way to make it happen. it DOES NOT happen all the time.. if i notice it happening i can shift to neutral and give it a couple slight revs and it goes away. i have used M1 5-30 and rotella T6 5-40 in it and it has occurred with both, I have flushed the motor once with seafoam and once with MMO, Oil pressure at hot idle is ~37 PSI, while cruising its at 40-42 psi and climbs to 60 PSI at WOT.
my question is... am i dealing with a bad roller on one of the lifters or is it a oiling issue? oil is clean when i change it so i don't believe it is a sludge problem.
should i bite the bullet and replace (upgrade) the cam and lifters or am i dealing with a weak oil pump?
any help is much appreciated. Thanks
Old Feb 16, 2018 | 08:16 PM
FFDP's Avatar
Welcome to a LS engine.
Either deal with it like 90% of us do or replace the parts and have it still do it later on. Heck even brand spanking new GM lifters will tick right out of the box at idle.
It's not an oil pressure problem, you are have far more pressure than the GM minimum specs to keep the engine alive and healthy. Factory lifters are just noisy, the sewing machine and lifter tick sound are just the way they are.
Old Feb 16, 2018 | 08:25 PM
AZ414's Avatar
Registered User
I know about the piston slap and "sewing machine" valvetrain. this is sometimes a LOUD tap... bad enough that i can hear it clearly over road / tire noise.
i have just never heard a healthy LS be quite that loud. lol but hey.. if i can use it as a excuse to the wife to throw a cam, springs and long tubes on it then so be it.
Old Feb 17, 2018 | 12:05 PM
darkirish63's Avatar
I would add that it's not just GM lifters that can be noisy in an LS setup. My Johnson lifters chirp until she gets up to temp and then all is well. Having lost GM lifters twice, I'm always paranoid when I hear them at startup but the noise is non-metallc in nature...more like a little bleed off when cold. Just makes me nervous. I don't get on her until she's nice a warmed up 😎.
TURBHOE
Jan 18, 2010 10:37 PM
blue2003ls
23
Oct 10, 2008 11:14 PM
mred
Sep 2, 2008 10:59 AM
TooExtreme2002
18
Jan 16, 2006 11:49 PM
bigguy75inches
16
Apr 5, 2004 11:22 PM
