Installing Pulley
Old Nov 16, 2002 | 11:52 PM
Default Installing Pulley
i'm installing the crank pulley on 2001 5.3, could someone give me the right part # for the pulley puller so i can get if off. THANKS
Old Nov 17, 2002 | 04:11 AM
CashDudeHomie's Avatar
Default Re: Installing Pulley
You need a 3 jaw puller.
Old Nov 17, 2002 | 10:32 AM
JWRENCH's Avatar
Yea it's a real small one. Like a 3 or 4 inch. and it pulls on the little tabs on the inside circle, not out where the belt runs. But you already knew that huh... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 1, 2002 | 08:54 AM
eallanboggs's Avatar
You also need a way to keep the crank from turning while you take the factory bolt out. I used a chain wrench that plumbers use on cast iron galvanized pipe. You also should buy a longer than stock bolt to help get the ASP pulley started on the crank snout. I got a 16X2X120mm for $2 at a local hardware store. It's 17mm longer than stock and really helps when trying to get the new ASP pulley started on the crank. The pulleys will make a big difference. I noticed the change as soon as I left the driveway.
thunder550
Oct 8, 2015 04:53 PM
wrb002
Aug 31, 2015 12:00 PM
chevysten
Aug 13, 2015 07:36 PM
bigsapper
Jul 28, 2015 12:56 AM
