Injectors ??????????
Old Dec 15, 2005 | 06:01 PM
  #31
67SS509's Avatar
10 Second Truck Club
Originally Posted by litreddevil
well guys all in sig and a good dyno tune from thunder,it dyno 338 at the wheels i don't know justin's screen name he was their.u'll can call the bs all u want show some money and i will put the 5.3 back in and show u(and not no pocket change some real money worth my while)
damn then if u'll don't belive that then u won'y belive a 4.8 sbrc all motor cam and a good tune no i mean no head work r injector changed ran 13.51 don't remember mph i will find out.
This is copied from an old post also..........
A Tb Stall Is Fine Unless U Want To Go Ball Out. I Am Now Running A 3600 Stall And 4.56 Gears With Thewhen I Had The 5.3 And The 3000 Stall I Was Cutting Some 1.64 60' Times So Yes A Tb Stall Will Help U But U Can Go Get All Of It And Put Vertter And Gears.
I Don't Care For The Tb Stall I Had One And Move On Alot Of People Like Them I Don't I Feel In Alot Of Cases It Leaves Alot Of Improvement Still Their To Get That You Will Not Get Out Of A Custom After Market Vertter
__________________
Old Dec 15, 2005 | 06:06 PM
  #32
Zick's Avatar
Uh oh.....
Old Dec 15, 2005 | 06:23 PM
  #33
litreddevil's Avatar
Banned
Like I Said Before Money Talks Bull **** Walk And If U'll Would Like U Can Come See Me In Stall It.
Old Dec 15, 2005 | 06:25 PM
  #34
Banned
WELL U'R FACTS R JUST NOT TO GOOD CAUSE THUNDER HAS DYNO GRAPHS FOF MY TRUCK.
Originally Posted by 02sierraz71_5.3
Something doesnt add up you swap to a 6.0 with more work including ported heads and run only 2/10's better??????
Why are you shifting with a light if your in an automatic and on top of it you say your shifting around 6900 rpms. I know for a fact that the cam your using the power starts falling off around 6000 rpms with the stock top end in a 5.3. Ive lost et. by taking my motor well out of the power band like your doing, the shifting thing doesnt explain anything.
I really hope you ran those time NA but I seriously dont believe you did it with just what info you are divulging.
Ive seen some very stealthy Nitrous setups where youd practicly have to take stuff apart just too see it.
Old Dec 15, 2005 | 08:00 PM
  #35
02sierraz71_5.3's Avatar
GRAPHS OF you spraying it Im sure, but regardless your tellin me that with a cam in the 220 range on a 112 your making peak power at 7k rpms. The more you talk the more my suspicion is confirmed.
To run that time in the 1/4 your 1/8 would be around 8.01 based off your et flywheel power would be around 440 for a 4500 lb truck
440 * .2 = 88 drive train loose
440-88=352 rwhp thats one hell of a miracle cam you got there
now spraying a 75 shot I can see it but not NA
too many people run cams almost identical to that one for you to be 1+ second quicker
Old Dec 15, 2005 | 08:40 PM
  #36
12sec.5.3's Avatar
I ran my 12.80 pass with stock injectors on my 5.3 also. And I still have stock injectors on my 6.0. Wonder If I need to step up my injector size?
Old Dec 15, 2005 | 08:48 PM
  #37
12sec.5.3's Avatar
I believe Randy is telling the truth. Compare his 1.65 60' to my 1.72 and his 12.59 to my 12.81. Like the old saying goes, "one tenth on the 60' is two tenths on the big end". Like Randy mentioned, there is also a 4.8 with cam only, headers, and converter, with tuning shifting at 7,000 ran 13.51 which is very respectful. Southern boys got some fast trucks.
Old Dec 15, 2005 | 08:50 PM
  #38
I dont doubt he ran that time at all what I doubt is that he did it NA with only a cam.
Old Dec 15, 2005 | 10:25 PM
  #39
goshawk23's Avatar
Truck addict
i didn't see any nitrous at thunder shootout in 04. he ran a 12.7 something that i witnessed at the event.
Old Dec 16, 2005 | 06:54 AM
  #40
Banned
02SIERRAZ71 lets do this u build a 5.3 and i will put another one in my truck but cam only and n/a and i will race you for title and yes i will put sand bags to come up the difference.put up r shut up move on
and put stop u'r guessing here is the break down
60'-1.64
330-5.016
1/8-7.92 @ 84.00mph
1000-10.45
1/4-12.59 @104.60
i made 338hp and 340tq on tr dyno so u can do some math cause u r close on that part.can't belive u can do alittle math did u'r mother help u.
