I'm so stoked!!!!
Old Sep 23, 2004 | 02:43 PM
  #51
BigBlockChev572's Avatar
Talking
Originally Posted by moregrip
We don't really have tables, just a 8" wide & 10" deep platforms, all standing, no way to support elbows.
Tonight we did our first T joint. 7018 rod. First we tacked together an H then went to it.
All I can say is, I need practice, My first bead was riding too high on the joint, got some slag between the lower tow line and the base metal.
My amps were to low, course it took me all night to figure that out, when I turned them up it was like butter.
I bent the top edge of the electrode a little to help with the angle, I'd say my electrode angle was about 15-20 degrees with the lower edge of my electrode pointed toward the center of the joint.
More on Monday
Your starting to sound like an expert already! One thing about doing a T-joint with 7018 is don't look at the rod, look at the puddle that follows it. If you can see a nice I guess you could call it a "half circle" following the rod evenly and smoothly all the way across the T-joint you know you'll have a good weld before you even chip slag! Keep about a 40-45 degree rod angle and aim for the center of the joint. Keep up the good work! Post pics!
Philip S.
Old Sep 23, 2004 | 06:47 PM
  #52
jdustu's Avatar
Originally Posted by marc_w
Thanks, jdutsu...
Does it help to mention that I can solder with the best of 'em?
No, honestly I took 4 years of electronics (daily soldering), and combining that with automotive stuff, I can definitely understand the "odd positions" that are sometimes needed to get the job done. (under dashes, engine bays, etc.) I imagine you need to be a lot more accurate welding.
that'll help i'm sure....actually the odd positions comment was directed at moregrip, he was talking about getting steady, but it's a pretty general thing.....honestly, i haven't soldered a lot, but in welding most of the time there is a margin to work with......obviously somethings have to be perfect, and the guys who can be perfect are very well rewarded......you want it to look good, but making it hold is the biggest deal......
Old Oct 2, 2004 | 01:56 AM
  #53
moregrip's Avatar
what a rush!
This week we continued filet welds with 7018. Running an initial generous bead, then an second bead just below the first, then a final bead just above that. Perfect right triangles........yeah right . Seems kinda funny, I laid my absolute best weld the other night, just to cover it with a just so so bead. Man, what luck. Practiced welding with the 7018 HOT, about 170 amps, WOW, I had to really push my stick in to keep my tow lines in check and not spread them too wide. I think I prefer about 140-150amps with the 7018. Also tried pushing my welds instead of dragging them, very interesting to see that the weld pool will still follow even when your electrode is angled in the opposite direction
We welded for 3 hrs straight one night, my damn hand/forearm was seriously sore from chipping slag all night and it doesn't always come off so easy folks! trust me on that.
that's about it, lots of practice this week.
Old Oct 2, 2004 | 11:49 AM
  #54
jdustu's Avatar
That's cuz you have the amps set up way too high.....if you have the temp right the slag should just curl up and fall off.......
Old Oct 2, 2004 | 07:39 PM
  #55
moregrip's Avatar
what a rush!
I didn't really like welding at that high amps, but the instructor wanted us to get used to welding in different situations.
Old Oct 2, 2004 | 08:41 PM
  #56
Yeah, if you have the settings absolutely perfect, the slag will actually fall off as you weld!
Philip S.
Old Oct 2, 2004 | 08:44 PM
  #57
3 hours straight! Good job! Hey, how many times have you arced your eyes?
Philip S.
Old Oct 2, 2004 | 09:07 PM
  #58
moregrip's Avatar
what a rush!
I was soaked in sweat, and tired as hell after that night. whew!
Old Oct 8, 2004 | 07:46 PM
  #59
moregrip's Avatar
what a rush!
Well, we did some vertical welding this week using 6011 sticks.......them little suckers are powerful! whow! Can and does burn right through your metal, the weld pool stays put though, not much movement at all. I could use some practice on this one for sure.
When I was welding with these things it looked like a fire was covering the weld pool, very different than what I've used so far. Oh, and they smell kinda funny too.
Old Oct 9, 2004 | 01:35 AM
  #60
jdustu's Avatar
if you're doing vertical up then you need to turn your juice down and get a smaller dia. stick........
