Identifying pre-04 blocks?
Old May 30, 2011 | 11:18 PM
durty's Avatar
Default Identifying pre-04 blocks?
I have a lq4 shortblock and was looking for head bolts/studs for it but I'm not sure what year it is. How can I go about figuring out which year it is?
Old May 30, 2011 | 11:33 PM
JFOLM's Avatar
Run a long head bolt in all the holes and see if it is too long.
Old May 31, 2011 | 07:35 AM
bullygoat's Avatar
Read the VIN off of the block so you get all of the correct parts.
Old May 31, 2011 | 02:01 PM
durty's Avatar
Where is the vin located on the ls motors? this would be my first voyage into ls land.
Old May 31, 2011 | 02:34 PM
bullygoat's Avatar
https://www.performancetrucks.net/fo...6&postcount=16
Old May 31, 2011 | 05:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Never been able to see that on the back of the block but there is a casting date on the front right. usually 1 letter followed by 3 numbers. E064 is what's on the one in front of me. Will post a picture tonight when I het home.
Old May 31, 2011 | 06:00 PM
1FastBrick's Avatar
You can also stick a coat hanger in the holes 04 up will all be the same depth roughly 2.777 from hole bottom to the deck surface. Early will be deeper.... except the ends will be shorter.
Old May 31, 2011 | 07:50 PM
durty's Avatar
Well I ran the crankshaft casting number, #12552215, comes back to a 99-00, other than it having the thicker crank flange are there any downsides to it? I plan on running a th350 behind it and a s480 in front lol
Old May 31, 2011 | 07:56 PM
durty's Avatar
Also the only numbers I see cast into the front besides the 6.0L is G01 on the passenger front
Old May 31, 2011 | 08:33 PM
1Bear's Avatar
Just as 1FastBrick was saying, you can see the location of the Julian Date Calender and stamping area here in this picture of Copper&Black's build.
