I screwed up
Old Mar 31, 2020 | 09:32 AM
  #21
AngryBear's Avatar
Originally Posted by The_W
Not to scope creep the thread but what kind of steering column did you put in? Just factory replace or aftermarket? I put a manual in my 2000 silverado and been looking around.
I didn’t replace it. I has to come out to remove the DBC throttle pedal assembly. My truck is factory manual. But I’d think that if you just remove all the shifter crap from yours and replace the column covers with manual trans ones (if you can find them...might be a hard find), you’d be golden.
Old Mar 31, 2020 | 09:53 AM
  #22
The_W's Avatar
ah ok, yea I removed the column shifter already, But like you said column cover for a manual is like finding a unicorn. Some said try a trail blazer which I found in a junkyard but it doesn't work.
Old Mar 31, 2020 | 09:58 AM
  #23
AngryBear's Avatar
You could always try your hand at fiberglass and try to fill and smooth the holes. Then paint it. Worth a shot maybe.
Old Mar 31, 2020 | 01:07 PM
  #24
The_W's Avatar
Yea that is not a a bad idea, might get a spare automatic shell since that is whats on their currently. I am sure there are 5 speed shells out there just got tired of looking haha. I appreciate the feed back, good luck with your issue!
Old Mar 31, 2020 | 01:19 PM
  #25
AngryBear's Avatar
Much appreciated. Keep looking for those column covers though. You'll find a set. Or, you might find a new hidden talent working with fiberglass! Good luck
Old Mar 31, 2020 | 07:39 PM
  #26
AngryBear's Avatar
Originally Posted by RB04Av
There are 2 RAP fuses. Might be labelled something else; MBEC or LBEC specifically.
They are BIG 50A (red) fuses, across the "top" of the fuse block, nearest the engine. RAP = Retained Accessory Power; it's how all the stuff that stays running after you shut off the engine but before you open the door, gets its power.
You were right. 40a ignition fuse blown under the hood. Confirmed with meter, problem solved. You'd think a blown 40 amp fuse would be obvious. Thank you so much.
Old Mar 31, 2020 | 07:58 PM
  #27
AngryBear's Avatar
Thanks to everyone for the help in solving this issue. Lesson learned. Check fused with a meter. A blown fuse isn't always obvious by looking at it.
Old Mar 31, 2020 | 08:18 PM
  #28
RedXray's Avatar
100% Redneck
I'm looking too after I moved the auto shifter to the floor
The part number for the manual column upper shroud is 26072994
Look for these vehicles in a salvage yard (the manual S-10 is probably the easiest to locate)
Chevrolet AVALANCHE Base 2002
Chevrolet BLAZER 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
Chevrolet S10 1998, 1999, 2000, 2001, 2002, 2003, 2004
Chevrolet Silverado/Sierra Base 1999, 2000, 2001, 2002
Chevrolet Silverado/Sierra 2500 Base 1999, 2000, 2001, 2002
Chevrolet Silverado/Sierra 3500 Base 2001, 2002
Chevrolet SUBURBAN Base 2000, 2001, 2002
Chevrolet Tahoe 4DR Base 2000, 2001, 2002
Old Apr 1, 2020 | 09:19 AM
  #29
RB04Av's Avatar
5 Year Member
:thumbsup:
Old Apr 1, 2020 | 10:06 AM
  #30
2002_Z28_Six_Speed's Avatar
The part number for the column cover is in my manual conversion thread. It fits but you will have to color match it. Very easy to do. Get the correct color and some adhesion promoter. SEM Solve before painting.
