I screwed up
Old Mar 30, 2020 | 10:26 AM
AngryBear's Avatar
Originally Posted by RB04Av
There are 2 RAP fuses. Might be labelled something else; MBEC or LBEC specifically.
They are BIG 50A (red) fuses, across the "top" of the fuse block, nearest the engine. RAP = Retained Accessory Power; it's how all the stuff that stays running after you shut off the engine but before you open the door, gets its power.
I looked at all of those big fuses. All look good. I assume it’s very obvious when they blow. I didn’t use a meter on them or anything.
Old Mar 30, 2020 | 11:27 AM
RB04Av's Avatar
5 Year Member
I'm not real big on "obvious" where fuses are concerned.
Use a meter.
Old Mar 30, 2020 | 11:31 AM
AngryBear's Avatar
Use a meter.
Yeah. I’ll check them tonight.
Old Mar 30, 2020 | 09:34 PM
_zebra's Avatar
makes children cry
i don't remember exactly which ones they is, but you might also check the relays in the block behind the clutch pedal.
Old Mar 30, 2020 | 10:16 PM
AngryBear's Avatar
I did not see any relays under there, but I’ll check again. Right now I’m waiting on Matco to resolve my scanner software issue to see if I might have smoked my BCM.
Old Mar 30, 2020 | 11:27 PM
_zebra's Avatar
makes children cry
yeah, at least on my 99, there're 3 or 4 of them. it's got a black square-ish cover with an unusually-long/deep plastic retainer nut in the middle. it's where you'd also plug in a brake controller harness.
Old Mar 31, 2020 | 06:31 AM
AngryBear's Avatar
It’s white, right? I’ve got nothing there. No relays. Keep in mind, this truck is poverty spec. No power anything, no AC, no cruise....
Old Mar 31, 2020 | 09:01 AM
RB04Av's Avatar
5 Year Member
In 05 the relays are some in the underhood fusebox, and some on the pass side of the dash up against the door.
Check those fuses first though.
Old Mar 31, 2020 | 09:05 AM
AngryBear's Avatar
I’ve tested all the relays. All relays are good. I’ll check tonight on the status of those fuses. My 5 year old daughter required my undivided attention last night.
Old Mar 31, 2020 | 09:27 AM
The_W's Avatar
Not to scope creep the thread but what kind of steering column did you put in? Just factory replace or aftermarket? I put a manual in my 2000 silverado and been looking around.
