I need some help troubleshooting
Old Sep 8, 2010 | 07:37 PM
SmokinHot98's Avatar
Default I need some help troubleshooting
Before i did the swap I had a pre-cat o2 go out on the passenger side, so i replaced it w/a Bosch part # 13178 OE replacement. Well it threw a code (can't remember which one) but it was stating the heating element in the o2 wasn't working. So i held off and did the swap and replaced it with another one and changed the driverside too. And they both don't heat up. Could it be an electrical issue? After awhile when the exhaust gets hot they start working, I'm stumped b/c these are the correct ones.
Old Sep 8, 2010 | 11:39 PM
budhayes3's Avatar
PT's Slowest Truck
Sometimes long tube headers don't hold in enough heat and you get O2 sensor heater codes
Old Sep 9, 2010 | 05:25 AM
but what would cause the o2's from not heating up on there own like they should?
Old Sep 9, 2010 | 07:10 AM
Truckshop's Avatar
check the fuses
Old Sep 9, 2010 | 12:34 PM
They're all good from what I seen
Old Sep 9, 2010 | 01:32 PM
Mrgoodwrench3's Avatar
You should be running AC Delco or Denso O2 sensors. I have seen too many aftermarket sensors not function correct.
Old Sep 9, 2010 | 09:18 PM
do you happen to know what part numbers i'd need of either the 2?
Old Sep 10, 2010 | 05:19 AM
is there a ground in the harness I may have overlooked or isn't getting a good enough ground?
Old Sep 10, 2010 | 06:30 AM
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
Why not have your tuner delete the sensors completely? That way you never have the issue again.
Old Sep 10, 2010 | 12:24 PM
I don't want to go with an SD tune, which is What would have to happen if they were
Jim98TA
11
May 2, 2017 09:22 PM
drummer0415
11
Oct 24, 2015 08:16 PM
muncie21
Sep 7, 2015 09:55 PM
rojeho
Jul 12, 2015 06:10 PM
dewmanshu
May 15, 2006 07:25 AM
