I Need a Hand With Some Horns
Old Dec 1, 2006 | 03:44 PM
Rescue11B's Avatar
Default I Need a Hand With Some Horns
Does anyone know which wire is hot on the horn plugs. Reason i'm asking, i'd like to wire up an aftermarket horn without using a seperate button. It be cool if I could have it wired directly to the wheel.
Old Dec 2, 2006 | 09:18 AM
budhayes3's Avatar
PT's Slowest Truck
Hmm, I didn't even realize they had 2 wires now, used to be one hot wire and the horn grounded to the body. Sorry I don't have the direct answer for you, but the easiest way to tell is to unplug the horn and check the pins with a test light....have someone lay on the horn for you and check and see which one lights up, that's your hot wire. Hope this helps
Old Dec 3, 2006 | 07:17 AM
Rescue11B's Avatar
This helps out alot man! Thanks for the reply. I let you know how it turns out.
Knightcrawler
Jul 20, 2016 03:29 PM
Vortec350ss
Oct 10, 2015 09:11 PM
Pimpinpete
Sep 8, 2015 07:39 PM
