I Need a Hand With Some Horns
Does anyone know which wire is hot on the horn plugs. Reason i'm asking, i'd like to wire up an aftermarket horn without using a seperate button. It be cool if I could have it wired directly to the wheel.
Hmm, I didn't even realize they had 2 wires now, used to be one hot wire and the horn grounded to the body. Sorry I don't have the direct answer for you, but the easiest way to tell is to unplug the horn and check the pins with a test light....have someone lay on the horn for you and check and see which one lights up, that's your hot wire. Hope this helps
