i am prety pumped up, keeping the shiping companys busy.
Originally Posted by parish8
the gauge only works with the fjo wideband set up, it was prety expensive too.
rg, you mean with a big shot right? i think it is at least posiable, dont know if i can do it but i will try. last truck got a best of 11.92 with 8psi and a 75shot, i got up to 9psi and a 100shot on the street but no track time, now drop 500lbs, add a front locker. hmm, could happen.
single digit dreamer
i HOPE to run the 1500 autotrack transfer case and 1500 front end for awhile but dont know if that will work out or not. if i have to change the transfer case and rework the driveshafts i will probably try and get the front diferential in right away, have to leave out the front drive shaft till i get some 4.10's in the rear if i do that. hell yea, i want a locker in the front and a good posi in the rear, i am all ready turning over 3/4 tires with just a 100shot, might just end up smoking the tires once i get moe power.
Did you happen to get the front drive shaft also for the HD front diff and HD t-case?
Trying to come up with all contingent (sp?) possibilities so you aren't suprised by anything.
