HVAC hot air blowing on all settings
Old Mar 26, 2016 | 02:28 PM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
Did you do the wrong actuator maybe?
Old Mar 26, 2016 | 02:34 PM
  #22
Wolftrk99's Avatar
Time to get the dmm out and check voltage at the connector
Old Mar 26, 2016 | 05:25 PM
  #23
tgui's Avatar
Perhaps! Which pins should I test?
Someone mentioned having to use a dealer tool to reprogram?
Also, I just turned it by hand with HVAC running and got cold air. Nipples are still hard.
Old Mar 26, 2016 | 10:08 PM
  #24
There isn't any reprogramming on the 99-02's. That's a 2003+ thing.
Old Mar 26, 2016 | 10:32 PM
  #25
Wolftrk99's Avatar
Being an auto system there may be a synchronization process but i will have to look it up tomorrow.....
Old Mar 26, 2016 | 11:07 PM
  #26
2002_Z28_Six_Speed's Avatar
His is the single system, not the dual zone.... Id rather do the passenger side than the drivers side anyday..... 1/4" snapon pass through ratchet wirks awesome for those
I didn't realize all these were so different. On mine the drivers side is by the blower motor under the passenger side of the dash and the passenger side is buried under the dash in the center under the light detector. Very hard to get too.
Old Mar 27, 2016 | 12:17 AM
  #27
Wolftrk99's Avatar
03-up dual zones are a pain, and run through the hvac module, bcm, and pcm.... 99-02 are simple control head and actuators... Some inputs from the pcm but mostly for idle and high rpm shut down to protectvthe system... Ive done the passenger side actuators on newer systems through radio opening and glove box... PITA but doable... As i said i have a low profile 1/4" snapon ratchet set that makes it easier!!!!
Old Mar 27, 2016 | 09:47 PM
  #28
tgui's Avatar
Got it working. There are a ton of people with magic dances to get it to work. I found a simple one that works for me.
Turn all AC off and heat to coldest temp
Disconnect neg battery
Connect battery
Get in truck, close door
Turn ignition on but don't start motor
Wait a couple minutes and listen to your actuator chirping. I felt it moving. It's discovering the bounds of the blender and can take a while.
Start engine and go for a drive to get heat in the system for easier testing.
Park, engine off, open and close door. Supposedly door open and close ends a cycle, what that means I don't know.
Start truck and test! Mine worked at this point.
Thanks all for the help! Once again, y'all helped out tons.
Old Mar 27, 2016 | 10:31 PM
  #29
Wolftrk99's Avatar
Opening and closing the door turns the RAP module off and causes everything to power down completely.... Glad its fixed....
Old Apr 3, 2016 | 02:42 PM
  #30
apex2112's Avatar
I have an 01 that is stuck in defrost were is that actuator? and how much of a pain is it to change.
Atomic
55
Feb 4, 2021 01:49 PM
2WDinSnow
Mar 16, 2016 02:38 PM
Luis3701
Mar 3, 2016 06:54 PM
Jonesy95
Feb 29, 2016 10:58 AM
XBlackXCheavyX
Feb 25, 2016 09:52 PM
