how would trans brake work
Old Aug 18, 2009 | 11:50 AM
  #21
ap2002's Avatar
Juan Transmission also built my transmission, lets just say he builts them well, my has been holding for a long time and know of plenty of people that is also running it...
blackbeast - sounds like you have a nice solid setup, a transbrake is the last thing i would be trying to do with the truck... make sure you test your truck first at the track, work out all your suspension mods first, make sure you got the right tire/wheel combo and maybe some caltracs, shocks etc.... a transbrake is useless without a solid suspension.... ESPECIALLy in an ext. cab...... i get 1.68 sixty ft at the track on motor and when i tried to spray a 125shot out of the hole it did NOT hold it cause i have no suspension for that.... thats why i have always sprayed it after the 60ft...
Old Aug 18, 2009 | 12:29 PM
  #22
lablackbeast's Avatar
doesn't know what quit means
well i guess i will do it just on the foot brake and if it hooks i ma try the 125 off the whole and then work my way on the suspension cause i am pretty sure that i ma have trouble but i have the t brake already so i want to try it awuevo .........
Old Aug 18, 2009 | 02:24 PM
  #23
LowBlack99's Avatar
Before you even consider a trans brake you need a driveshaft loop and a stronger driveshaft as well. You really need both without the t-brake with your power potential and weight as it is.
Old Aug 18, 2009 | 04:03 PM
  #24
ap2002's Avatar
let us know how it does!
any pics of your truck?
Old Aug 18, 2009 | 05:40 PM
  #25
nope its just an 05 extended cab black and a true sleeper lol on 05 17s
Old Aug 18, 2009 | 05:45 PM
  #26
well the truck is a vortec max are the driveshaft loop and driveshaft stronger???? anyone know???
Old Aug 19, 2009 | 12:40 AM
  #27
anyone know if the driveshaft loop and driveshaft from a vortec max are stronger????
Old Aug 19, 2009 | 12:45 AM
  #28
viciousknid's Avatar
Where's the Beef?
No they are not stronger. But look under your truck to see if you have a 1 piece or 2 piece driveshaft. 2 piece is harder to break.
Old Aug 19, 2009 | 12:48 AM
  #29
yea its a 2 piece so what would i really really need to be woring about???
Old Aug 19, 2009 | 12:58 AM
  #30
Where's the Beef?
Personally i'd take it out how it is. You've already replaced the 10 bolt and the transmission. Those are the 2 weakest links. If you trust the builder then you need to hit the track and start working on suspension to get traction.
