How much does a Gen III engine weight?
Baltimore Whore
here ya go 505 pounds tops.
Displacement 350ci
Horsepower 345 @ 5600 rpm
Torque 350 @ 4400 rpm
Firing Order 18726543
Bore/Stroke 3.90/3.62
Cylinder Block Y-block, aluminum w/iron sleeves
Bore Spacing 4.4 in.
Deck Height 9.24 in.
Head Bolts four per cylinder
Main Caps six-bolt, two longitudinal
Thrust Bearing Number 3
Crankshaft Cast nodular iron
Main Journal 2.558 in.
Rod Journal 2.099 in.
Piston Cast-aluminum, flat top
Compression Height 1.338 in.
Rings 1/16-inch top and second, low-tension oil third ring
Connecting Rod Powdered metal, 6.098 in. long
Camshaft 5140 steel, hydraulic roller
Cam Drive Single-roller 3/8-inch pitch chain
Cylinder Head Aluminum, two-valve, symmetric port
Valve Angle 15 degrees
Rocker Ratio 1.7:1
Intake Manifold Composite, 75mm throttle body
Fuel Delivery Multiport, sequential electronic injection
Ignition Distributorless ignition with eight coils
Exhaust Insulated dual-wall stainless steel manifold
ENGINE COMPARISON LS1 LT1/LT4
Height 25.3 27.2
Length 27.3 27.9
Width 30.4 29.5
Weight (lb)* 459 562 (automatic) 503 620 (manual)
*These weights represent fully dressed engines and may change slightly depending upon final production configurations.
Displacement 350ci
Rocker Ratio 1.7:1
Height 25.3 27.2
Length 27.3 27.9
Width 30.4 29.5
5.3lSilverado
25
08-29-2016 12:48 AM
Suburban2500
07-19-2015 04:50 PM
