how to make 15" wheels fit
Old Mar 8, 2010 | 04:53 PM
candleman5.3l's Avatar
Default how to make 15" wheels fit
i have a 00 silverado with disk brakes on the rear, and i cant get my drag radials to hook at the track..i have 410 gears and a 26" drag radial is killing my gear ratio..i was wondering if anybody has made a 15" wheel fit on my application, im wanting to buy drag et's or something of that nature..any help would be greatful..
Old Mar 8, 2010 | 05:21 PM
white1's Avatar
Someone makes a wheel that will fit, but I cant think who it is.
Everyone I know running 15's on the 99 up trucks, just ground a little off the caliper
Old Mar 8, 2010 | 09:03 PM
quicksilverado's Avatar
You will have to grind the rear calipers to make 15" rims fit. Its pretty easy to do.
Old Mar 9, 2010 | 09:26 AM
TXsilverado's Avatar
depending on the backspacing, you might get away with grinding stock calipers. if the backspacing is too much, you need s10 calipers and TONS of grinding.
Old Mar 9, 2010 | 06:12 PM
viciousknid's Avatar
Where's the Beef?
Grind it
Old Mar 9, 2010 | 07:57 PM
fastlt1's Avatar
12 Second Club
What is the recommended back spacing?
Old Mar 14, 2010 | 11:12 AM
well i did tons of grinding and it still didnt work..i had to un hook the rear brakes
Old Mar 14, 2010 | 11:35 AM
fastlt1's Avatar
12 Second Club
Where you trying to make steel or aluminum rims fit? How much back spacing?
Old Mar 14, 2010 | 04:42 PM
fastlt1's Avatar
12 Second Club
Suppose to be none up front.
Old Mar 14, 2010 | 05:49 PM
Evil Eric's Avatar
I had to do some moderate grinding. I was told that if i would use spacers it would require less material to be removed from that caliper, but I decided against the use of spacers.
