How to drain the fuel tank
Old Mar 21, 2013 | 05:37 PM
Default How to drain the fuel tank
Its on a 2000 silverado. The tanks full and it's going to be sitting a while so I want to put the fuel in the other vehicle. I have the motor dismantled so the fuel lines are accessible. I tried turning the key on and the pump only ran a few seconds and shut off. How do I get it to run constantly so I can drain it into a gerry can?
Old Mar 21, 2013 | 06:09 PM
kbracing96's Avatar
Pull the fuel pump relay out of the fuse box under the hood and jump the main power across it.
Old Mar 21, 2013 | 06:24 PM
There are like 5 or so pegs on that relay, do you know exactly which ones? I don't wanna screw it up.
Old Mar 21, 2013 | 06:39 PM
kbracing96's Avatar
Pins 30 and 87 should do it.
Old Mar 21, 2013 | 07:21 PM
Thanks I'll give that a shot
Old Mar 21, 2013 | 09:56 PM
06murder's Avatar
Make sure you use a in line fuse when try to bypass
Old Mar 29, 2013 | 08:40 AM
nonnieselman's Avatar
Pin 30 is fused from the fuel pump fuse which should be a 20 Amp to the right of the relay.
ss454327
Oct 17, 2015 03:43 PM
cosb
Aug 24, 2015 09:08 PM
Sevex
Aug 22, 2015 12:12 AM
ss4chad
Aug 15, 2015 02:25 AM
