How do the 2" 4" drops hook up ?
Old Feb 3, 2003 | 10:08 PM
GMC SKI's Avatar
Default How do the 2" 4" drops hook up ?
I been considering dropping the truck and adding some new wheels i think i have decided on the 18" MKW9's rims with nitto 555r's 305 45 on the rear and 295-45 555's on the front
How will this tire combo look on a stock height Truck ?
i don't want it too look like a monster truck but can live with some space in the wheel well's
If i have to go with a drop kit the Hotchkis 2"4" drop is the one i'm thiking about ..
How does it hook up on the street I don't wanna sacrifice my potential to hook up on the street or track
any Ideas on what i should do ?
thanks
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Jim
Old Feb 3, 2003 | 10:21 PM
1 BAD GM's Avatar
Default Re: How do the 2" 4" drops hook up ?
When I had my Hotchkis 2/4 and a 2800 stall converter I had massive wheelhop. I decided to get rid of the Hotchkis kit and went back to stock for a while. The stock setup hooks much better than the Hotchkis kit.
Then I decided to go low again, but this time went with the DJM 4/6. I did not hurt my hooking performance close to as bad as the Hotchkis kit, eventhough it is lower. I would think that the DJM 2/4 would hook atleast as good as my 4/6, so I would recommend that. I loved the way that the Hotchkis kit handled, but it is a horrible setup for hooking in a straight line.
Old Feb 3, 2003 | 10:25 PM
GMC SKI's Avatar
i wonder if at all there is going to be a big difference in the ext cab and the reg cab hooking abilty ?
Also what shocks were you running on your setup ?
Stock or aftermarket ?
Old Feb 3, 2003 | 10:32 PM
JSmith's Avatar
I'm going to plug my Hotchkis drop. I've never gotten any wheel hop. I'm also still running the stock shocks. Keep in mind that the Hotchkis drop is more of a performance handling drop, hence the progressive rate coils up front.
Old Feb 4, 2003 | 01:03 PM
1 BAD GM's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GMC SKI:
<strong> i wonder if at all there is going to be a big difference in the ext cab and the reg cab hooking abilty ?
Stock or aftermarket ? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was running Doestch Tech shocks front and rear with the Hotchkis kit. I think that the problem was that the Hotchkis leafs only had like 3 leaves and the stock has 4 or 5 (can't remember right now). I think that this caused the leafs to flex more and caused my massive wheel hop.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JSmith:
<strong> I'm going to plug my Hotchkis drop. I've never gotten any wheel hop. I'm also still running the stock shocks. Keep in mind that the Hotchkis drop is more of a performance handling drop, hence the progressive rate coils up front. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I never got any wheelhop with the Hotchkis kit either until I did the higher stall converter. And I see that Jim has a high stall and a blower, so I would have to stick to my recommendation of the DJM kit.
Chris
Old Feb 4, 2003 | 03:08 PM
JSmith's Avatar
Maybe I'll run into it then once I install a converter this summer?
Old Feb 4, 2003 | 06:19 PM
red53gmc's Avatar
I'm pretty sure the stock leafs have the same as the Hotchkis setup. I thought that was odd when I swapped them out.
The hotchkis rear setup is better for hooking than the stock leafs because they are stiffer. I had wheel hop with the stock leafs and I have never had any wheel hop at all with the hotchkis and run stock size Bilsteins.
Ext. cabs may be a different story though.
<small>[ February 04, 2003, 06:21 PM: Message edited by: red53gmc ]</small>
Old Feb 4, 2003 | 06:30 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red53gmc:
<strong> I'm pretty sure the stock leafs have the same as the Hotchkis setup. I thought that was odd when I swapped them out.
Ext. cabs may be a different story though. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">and this is with a 3200 YANK <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
06droppedcrew
Nov 17, 2015 10:56 PM
RONIN LSX
Sep 15, 2015 12:57 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
94f150
Sep 13, 2015 06:39 PM
