Horns
Old Sep 27, 2012 | 01:51 PM
nonnieselman's Avatar
Default Horns
My fuse keeps blowing when i hit the horn.. so instead of trying to figure all that out.. im gonna replace them and put my own relay in..
What kinda horns would yall suggest??
I want something loud.. but no train horns
Old Sep 27, 2012 | 01:52 PM
Found this Bad Boy One-piece 139dB Air Horn and Compressor Combination for 40 bucks..
Old Sep 27, 2012 | 03:26 PM
black00chev's Avatar
Slowest turbo build ever!
I have the same problem and its a bad horn. Too much resistence in the horn causing the fuse to pop. I just keep a bunch of extra 15a fuses laying around since I tend to lay on the horn for awhile when someone pisses me off!
Been wondering the same though as what's a good replacement other then using new factory horns. They're too wimpy.
Old Sep 27, 2012 | 04:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The horns get water in them, then short out. Could be one, or both, but it's really common.
Your truck already has a relay, etc. You could just remove the factory horns, and then plug in whatever aftermarket horn you chose.
Old Sep 27, 2012 | 04:08 PM
2000chevysilverado's Avatar
Y not train horns very usefull
Old Sep 27, 2012 | 04:31 PM
Need something small and compact..
im pretty sure i know how they got water in them
they use to be loud.. but after a few off road adventures,, they sounded like they had water in them.. haha woops.
Old Sep 27, 2012 | 06:25 PM
So does anyone reccomend a good aftermarket horn for us people that need a new one(s)?
And something that has a deeper tone then factory. I want the horn on my truck, to sound like a truck... Not a honda civic
Old Sep 27, 2012 | 06:33 PM
5speedsilverado's Avatar
i have one mustang horn and an econoline horn on my truck lol, benefit of working at a ford dealer. much better then the stock setup
Old Sep 27, 2012 | 06:50 PM
Napa has their "blaster" line of replacement horns, louder than stock, same style as stock. Direct bolt on, only about $24 each.
7301056 - low note, 132 db, 420 hz
7301057 - high note, 130 db, 500 hz
Old Sep 27, 2012 | 07:39 PM
Do you run these yourself or just something you found browsing?
