Help, wiring question
Old Apr 23, 2005 | 08:08 PM
Originally Posted by joesilver01
You still have windshield wipers?? .......... Reason i ask is ....I removed mine and was wondering if I can use that circuit for basically whatever I want now?? Like an amp lead for a stereo or whatever else I could run off that 12V??
yes i still have wipers! lol! i just tapped into the wire then put a fuse right after it.
Old Apr 23, 2005 | 08:42 PM
moregrip's Avatar
what a rush!
Originally Posted by greentahoe
You dont need traction control. It is still there. Remove your gauge bezel and the plastic cover will pop out. Behind it will be a wiring harness with a bunch of wires connected to the back of the plastic cover.
is it the one that faces outward? did you tap the wires or the panel?
Old Apr 23, 2005 | 09:06 PM
greentahoe's Avatar
Its the little square plastic piece that is under where the 4WD selector would be on the left of the steering wheel. I just tapped into the wires and then plugged the wire harness back into the back of the plastic piece and snapped it back in. Very easy to get to and tap into. I'll take a look tomorrow to see what wire I tapped into for my 12v key on source.
Old Apr 24, 2005 | 12:51 PM
moregrip's Avatar
what a rush!
ok, I found a tach input & ignition source in the wiring to the gauge cluster; still looking for a dimmer location. greentahoe, On the back of the light control box, i found the headlight output, but when I put the test light on it, it turns the headlights off, I forget what this means, been a while, what do you think? Also I'll be running 5 gauges total, will those small wires support all 5? I'm also going to fuse the power source; is a 3amp enough?
thanks folks!
713truck
Aug 18, 2015 09:32 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
