HELP Truck won't start !!!!!
Old Mar 6, 2004 | 05:14 PM
Silverdoman's Avatar
Default HELP Truck won't start !!!!!
I installed the new tranny guage in cluster. The guage wont read for some reason but thats no problem. I tested (green wire) switch for the dimmer side to control the light on the guage so I just stuck the wire into back of the switch turn on and heard a pop sound in the switch. I have park lights but no head lights. Everything else works including the fuel pump. The truck will start but shuts right off. I haved looked at all the fuses and all ok. How would you test a relay if one is bad. The door chime inside dose not work either. I have no interior lights also but I have dash lights.
James
Old Mar 6, 2004 | 05:28 PM
ThunderZ28's Avatar
12 Second Club
did you check both fuse boxes?
to check a relay you would need a meter
Old Mar 6, 2004 | 05:29 PM
ThunderZ28's Avatar
12 Second Club
also make sure none of your wires are touching any thung on the back of the circuit board or the gauge
Old Mar 6, 2004 | 05:33 PM
I drove the truck around the block before i hooked up the light to guage. The guage pegs to the left. I think the sensor is not grounded good. I have checked the relays with my meter and all have the same reading. I think the switch is the problem because no interior light either. I think the computer is looking for the DRL and not there causing it not to start.
Old Mar 6, 2004 | 05:51 PM
ThunderZ28's Avatar
12 Second Club
is this an autometer guage put in the dash where the factory one would go?
you should have one wire to a ground.
one wire to the trans sender
one wire made up with the 12v from the guage
one wire for the 12v for the light.( which i think is the one you are trying to use for the light correct?
this is basiscally how i wired mine. only i spliced into the green wire and did not stick to wire into the back,
you should have also fused the 12v lead going to the guage
Old Mar 6, 2004 | 06:17 PM
Truck runs again!!!!!!!!!!!! Yes. I found a fuse I over looked and blown.The guage I have it wired to a 12v fused supply. I ran two wires to tranny one to sensor and the other to a bolt on tranny which tested and have a good ground. Have doubled checked everything and all hooked up correctly. I'll mess with it tomorrow I'm tired of working on it. It looks great. Will let you know if i get it working thanks for your help Thunder
Old Mar 6, 2004 | 07:00 PM
ThunderZ28's Avatar
12 Second Club
no problem glad you got it going
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
