Help me find the bad wire
Old Aug 29, 2010 | 12:35 PM
mhotrodscooter's Avatar
Default Help me find the bad wire
Ive got a miss sometimes between 1500 to 2000 rpms. Is there anyways to find this easily? I just know it's a plug wire but how can I find out which one?
I've rubbed my fingers down each one hoping to get shocked, but nothing. Not getting any codes cause that's delete I think!
Old Aug 29, 2010 | 12:49 PM
Daryn's Avatar
Formerly darynC-10/23/10
if its missin on a cylinder. check your primarys with a laser temp gauge.... the missin one wil be 20-50* cooler
Old Aug 29, 2010 | 12:58 PM
It's not a steady miss it just does every once in a while I'm driving it! Started right after my last dyno runs!
Laser gun a good idea though!
Old Aug 30, 2010 | 02:27 AM
Blown06's Avatar
8 Second Truck Club
My guess is that your MAF has gone bad. I encountered this same problem on a ws6 that I was tuning and I couldn't figure out what the hell the problem was. Turned the MAF off and bam, car ran perfect.
If you had a bad plug wire, it would miss all the time, no matter what rpm.
Old Aug 30, 2010 | 05:54 AM
If you had a bad plug wire, it would miss all the time, no matter what rpm.[/QUOTE]
Not all the time! I've had wires that would only miss on top end around 6500k mark! I've had them miss only when it rains lol!
I hope it ain't the MAF
Old Aug 30, 2010 | 09:02 AM
LightFighter's Avatar
scanning it will tell you what cly is missing........ it could also be an injector or a faulty plug.. without a scanner get an extra plug and wire and check each coil first. once you see all coils fire then swap the wire on each cly... if the miss doesn't go away then you have to swap a know good plug around. if the miss doesn't go away then you know its something else. Time to start looking at other things. Having a scanner definitely makes it easier to narrow the search down
Old Aug 30, 2010 | 10:05 AM
So a scanner will find a misfire even if misfires have been delete?
I guess going one by one is the only way! Back to the ole school lol!
Old Aug 31, 2010 | 02:07 AM
Blown06's Avatar
8 Second Truck Club
find someone with hptuners, throw it into sd in the scanner and see if the problem goes away. if so, the maf is bad. based on your symtoms, thats what i'm guessing. I just can see how a busted plug wire can fix and unfix itself.
Old Sep 4, 2010 | 02:58 AM
Blown06's Avatar
8 Second Truck Club
Any updates on this.....
Old Sep 4, 2010 | 05:21 AM
Not yet Blown06, still haven't made it home yet!
