help with factory security system
Old Jan 14, 2006 | 01:14 AM
TJ's Avatar
TJ
Default help with factory security system
tyring to disable my factory security system.
ive installed a remote start on my 2500hd and i have to hit the unlock button, then the lock button to start the truck.
one step id like to get rid of.
if i remote start it with the doors locked, the alarm goes crazy.
2005 if it matter.
thanks
Old Jan 15, 2006 | 10:37 PM
CARGUYS SIERRA's Avatar
Default remote start
TJ the factory security in the 05 GMC is controlled by the bsm throught a data stream fromthe OBD2. When you installed the remote starter did you also install a DATA module to interface with the Remote start? You need a bypass kit for the passlock 2 system and a data module for the security.Also your remote starter brand if its any good will have a disarm output and a rearm output , tis controlls the GM system eliminating the need for lock and unlock woes. check out www.bypasskits.com for the module required.I use the GMBP module and it works great.
Old Jan 15, 2006 | 11:02 PM
TJ's Avatar
TJ
thanks. a buddy installed mine for me, as im not the best with electronics. its an omega brand piece, and i do have the passlock module thing.
he told me he could take care of me in about 15 minutes, that there are several features and settings within the box.
i thought it would be a simple "pull this fuse" type thing so i wouldnt have to bother him.
thanks for the info.
Corvette454l88
Sep 1, 2016 01:24 AM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
