help deciding where to tap FPR(ls6 intake swap)
Old May 28, 2008 | 10:24 AM
TXsilverado's Avatar
Default help deciding where to tap FPR(ls6 intake swap)
using a 97 vette fuel return style rail for this one. i want to keep it as clean as i can. im thinking about drilling and tapping the intake manifold for the FPR but after looking at this diagram of the way its run, im curious if i should keep it out in front of the throttle body or if its ok to put it behind the throttle body. it seems like it would see different vaccum variables between the 2 locations (more vaccum behind throttle body)
where do yall think i should tap? in front of the throttle body or behind?
here is a diagram of how its run on a 97 vette
Old May 28, 2008 | 10:47 AM
thunder550's Avatar
High on diesel fumes
Behind...you want manifold vacuum. Can you run a T off your brake booster line instead of drilling the manifold?
Old May 28, 2008 | 07:24 PM
7845's Avatar
Banned
back of intake has a small Tit where vaccum is drawn from for the FPR
Old May 28, 2008 | 08:56 PM
tarinitup's Avatar
9 Second Truck Club
I liked the Titty as well.
ARC
57
Feb 21, 2022 10:54 AM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Staggered 02
Aug 11, 2015 07:54 AM
