Which head should i use?
Old Jul 6, 2018 | 08:57 PM
Chevyboi32's Avatar
Registered User
Default Which head should i use?
Well to get started I have a 1994 Chevy K 1500 with a 5.7 350 throttle body injected in it everything on the truck is stock I wanted to swap out my cylinder heads but for my truck I don't know exactly what heads I should swap to or have any ideas as to where to start a few months ago I was able to get a hold of L92 cylinder heads off of a 2007 Cadillac Escalade 6.2. Now I don't know if the cylinder heads that I have would be able to fit on my truck so I'm looking for any ideas that you have or anybody has as to the direction that I should go with the cylinder heads now what I would like to do with the motor I would like to swap the cylinder heads I would like to put a different cam in the truck I'm just not sure where I should start any help to kind of point me in the right direction would be so greatly appreciated thank you so much guys
Old Jul 6, 2018 | 09:43 PM
FFDP's Avatar
Nothing is the same between an old school small block 350 and the LS engine.
Those cylinders will not work.
Most guys tend to swap to 96-99 vortec 350 cylinder heads or go aftermarket aluminum cylinder heads from a vendor. I'm not that up to date on what all there is for those old 350's but I'm sure you'll find a lot that can be done.
You are limited by the fuel system too. The TBI fuel system can't really be "tuned" so going to a carb isn't a bad idea.
Old Jul 6, 2018 | 11:01 PM
RedXray's Avatar
100% Redneck
Yep the L31 Vortec Heads from 96 to 2000. If you are going with a higher lift camshaft have the stud bosses machined down and threaded for screw in studs and guide plates. They have 64cc chambers that will boost compression ratios to 9.5:1
https://www.powerperformancenews.com...benchtop-mods/
truckman9
Jul 4, 2006 07:50 PM
ssralphca
Dec 24, 2004 11:24 AM
Flyer
13
Feb 9, 2004 03:32 PM
BadAndy
Dec 29, 2003 07:05 PM
Ryan23silverado
Nov 4, 2003 11:17 PM
