guys with ls1/ls6/fast90/fast92 manifolds come in
Old Aug 2, 2011 | 01:39 PM
TXsilverado's Avatar
Default guys with ls1/ls6/fast90/fast92 manifolds come in
i want to see what you did for a CAI. post some pics! im just looking to do something clean here soon to get rid of my MAF. the UPD tube has seen better days.
Old Aug 2, 2011 | 01:47 PM
max1's Avatar
Banned
home-made K&N , works like a charm, so far no vacuum leaks..
Old Aug 2, 2011 | 02:26 PM
Dezert1500's Avatar
LS3 intake count? AEM and I powdercoated the intake tube.
Old Aug 2, 2011 | 02:28 PM
if the LS3 sits as low as a ls1...yes! i'm guesing that's aluminum pipe? what componets went into this? it looks really clean!
Old Aug 2, 2011 | 02:36 PM
Dezert1500's Avatar
The LS3 is roughly, if not the same height as the LS1. It's just an AEM truck intake for 99-07 Silverados. I powdercoated the intake tube because I'm not a fan of the chrome, but they do come in a grey if you wanted grey to match your paint. Everything bolts up just as it did with the truck intake, the only difference is the angle which looks better with the car manifold anyway.
Old Aug 2, 2011 | 03:06 PM
man, i wish they would have made that intake out of some kind of plastic! did you grind the bracket off of the bottom side of it?
Old Aug 2, 2011 | 03:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Intakehoses dot com has aluminum intake tubing, and any size/shape/angle coupler you can imagine for very good prices. They also ship cheap & fast.
Old Aug 2, 2011 | 03:48 PM
im tired of the home made look lol. dezert, do you happen to know the diameter of the pipe that AEM uses? i'm looking for 4"
Old Aug 2, 2011 | 03:50 PM
Dezert1500's Avatar
The radiator hose bracket, ya I cut that off and used a flap disc to smooth it out. You can't tell a bracket was ever there after powdercoat.
EDIT: 4". The coupling that comes with the kit fits over the 90mm TB's and the intake tube perfect.
Old Aug 2, 2011 | 04:04 PM
if you wanted to lose your MAF, would the pipe be long enough to reach the filter?
