Gurgling noise coming from heater box?
Old Nov 25, 2013 | 11:53 PM
Flyin 1500's Avatar
Originally Posted by Ferocity02
Mine did this too, it was just because of low coolant. It would happen even when the low coolant light wasnt on.
+1. I had the same thing happen on my truck. Added some coolant and it was gone.
Old Nov 26, 2013 | 09:16 AM
"CARTER"'s Avatar
Registered User
Can it be low on coolant even if the reservoir is full?
Old Nov 26, 2013 | 06:10 PM
Suburbazine's Avatar
Yes, if there's a big enough air bubble that hasn't been bled properly.
Old Nov 26, 2013 | 08:52 PM
10 Second Club
Low coolant light was intermittent today. Checked the level this evening, was down about an inch below the full line. This happened a few months ago, I obviously have a slow leak somewhere. But, no signs of a leak anywhere under the hood or under the truck.
Old Nov 27, 2013 | 08:26 AM
Robert91RS's Avatar
Pressure tester can be rented and a vacuum kit can help pull trapped air bubbles.
Old Dec 10, 2013 | 10:14 AM
spent21's Avatar
park snout up on a hill and rev it for a while. bubbles will usually work themselves out that way.
you need to find that leak though. Could be a water pump, cracked head, or a bad head gasket. Ask me how I know...
2000 5.3 - Coolant in oil
Old Dec 11, 2013 | 10:11 AM
hog's Avatar
hog
My GMT 400's do this as well. Air in the heater core, you are hearing the coolant rushing to replace it.
peace
Hog
Old Dec 20, 2013 | 01:06 PM
jaawood's Avatar
How many miles when you changed the heads?
Old Dec 23, 2013 | 10:46 AM
spent21's Avatar
i think it was around 135k. It has about 160 on it now with no problems. it used to use a quart of oil between changes, but it doesn't do that anymore either.
85SS/85GN
Aug 7, 2015 04:30 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
00pooterSS
Jul 16, 2015 03:03 PM
00pooterSS
Jul 16, 2015 02:41 PM
lxcoupe
Jul 8, 2015 05:49 AM
