Got a LS1 block, took it apart, how's it look?
Bought this block last weekend from a member on here/Ls1tech. From a 98 Firebird with 110k on the clock. Looks like the cylinders are good to me, but you guys are the experts.
You really should check it out with the proper instruments, dial indicators, etc...just to be safe. Even though the cylinders look fine they could probably use a good surface hone at the least. They should be checked for taper and out of roundness though. It's always a good idea to check the alignment of the cam and crank journals also, although I'm sure that they're probably fine. IMO, it's not worth it to tear it down and put it back together without checking it out.
formerly 2004RST (changed 11/19/2012)
but really have it checked over & are you planning any type of cam swap piston swap or anything of the sort? i would keep it out of the vehicle till i got those parts in so you didn't have to pull the front clip again lol just my .02
Just a little update on this.
It's still completely disassembled in my living room. lol. I've got funds to either rebuild it with a little work done to it. or to toss some goodies on the 4.8. What you guys think?
I'd build the LS1, no replacement for displacement
calsdad
Jun 14, 2023 11:07 PM
