Gm Part #anyone?
Old Jul 13, 2008 | 12:26 AM
  #2131
h20son's Avatar
Originally Posted by COLDZ71
Any luck on these?
sorry, got busy this week, I'll make sure to check for you when I get back to work
Old Jul 13, 2008 | 03:06 PM
  #2132
COLDZ71's Avatar
Thank you, I appreciate it.
Old Jul 14, 2008 | 12:07 PM
  #2133
h20son's Avatar
ok, supposedly, its called a housing and has the place for the socket for the bulb in it already, so it doesn't look like just a gasket, but it could be, anyway, PN# 15691885 should be the '88-'00 lamps
Old Jul 14, 2008 | 07:59 PM
  #2134
COLDZ71's Avatar
Yes, housing is the correct term, not gasket. Awesome!!! Thank you very much!!!
Old Jul 16, 2008 | 06:05 PM
  #2135
1bad5.3's Avatar
okay I am looking for the passenger side fender for my 04 rcsb....any chance I can order it the same color so that I can swap it at home?
The vin isas follows:
1GCEC14TX4Z305093
Thank You!
Old Jul 16, 2008 | 06:10 PM
  #2136
SBTork's Avatar
ill take this one, as it's one of the rare times that I have internet access at work.....
pn for the fender is 88944419, and I don't think there is much chance of ordering a painted one through GM, sorry man
Old Jul 16, 2008 | 06:15 PM
  #2137
1bad5.3's Avatar
can I order this through you?... or is the thread just for part numbers.
Old Jul 16, 2008 | 06:31 PM
  #2138
SBTork's Avatar
well, this thread is just part numbers. I could order it for you, but I'd have to get it here, and then ship it to you which would be a decent amount of $$. I'd reccomend gmpartsdirect.com or your local GM dealer. You should be able to get it from your local dealer overnight.
Old Jul 16, 2008 | 06:32 PM
  #2139
SBTork's Avatar
it should run anywhere from $220-$240 or so, from a dealer.
Old Jul 17, 2008 | 04:29 PM
  #2140
cmatt's Avatar
Originally Posted by InchUp
Actually that 12577903 number was just for the oil pan cover to block off the cooler. I spoke with a different dealership and the guy found it right away for me, said I'd have to buy the lines, unbolt that cover (12577903) and then bolt on the lines and gasket. The correct part number is 15203890 for $142.87.
Truck in question, last 8 of the VIN # is "3f106240".
Will this P/N (15203890) also work for a 2007 Sierra classic with a 5.3L Flex Fuel? I'm curious if the connectors on the tubing will still mate up or if they're different.
I also need to check the P/N for the 34" radiator that has the oil/ trans cooler provisions that will fit a 2007 Sierra classic. BTW would it still happen to be 52487603?
Thanks.
