Gm Part #anyone?
#2133
#2134
Yes, housing is the correct term, not gasket. Awesome!!! Thank you very much!!!
#2135
okay I am looking for the passenger side fender for my 04 rcsb....any chance I can order it the same color so that I can swap it at home?
The vin isas follows:
1GCEC14TX4Z305093
Thank You!
1GCEC14TX4Z305093
Thank You!
#2136
ill take this one, as it's one of the rare times that I have internet access at work.....
pn for the fender is 88944419, and I don't think there is much chance of ordering a painted one through GM, sorry man
#2138
well, this thread is just part numbers. I could order it for you, but I'd have to get it here, and then ship it to you which would be a decent amount of $$. I'd reccomend gmpartsdirect.com or your local GM dealer. You should be able to get it from your local dealer overnight.
#2140
Actually that 12577903 number was just for the oil pan cover to block off the cooler. I spoke with a different dealership and the guy found it right away for me, said I'd have to buy the lines, unbolt that cover (12577903) and then bolt on the lines and gasket. The correct part number is 15203890 for $142.87.
Truck in question, last 8 of the VIN # is "3f106240".
Will this P/N (15203890) also work for a 2007 Sierra classic with a 5.3L Flex Fuel? I'm curious if the connectors on the tubing will still mate up or if they're different.
I also need to check the P/N for the 34" radiator that has the oil/ trans cooler provisions that will fit a 2007 Sierra classic. BTW would it still happen to be 52487603?
Thanks.
