Gen 3 to Gen 4 Silverado swap
Old Dec 5, 2023 | 07:42 PM
  #111
Harriman07's Avatar
Originally Posted by RDF1
If it is the camaro balancer it aligns with the truck accessories. If its the corvette balancer it wont.
You will need to call Circle D or Yank or some torque converter manufacture and tell them the specs of the engine and truck to get the converter you need.
Yea its very easy to piggy back the stock ECU to the Holley. But if you want easy... https://www.currentperformance.com/s...ation-harness/
I am in the same boat. I have a built ls3 and it has a 58x going in 07 classic that started life as 4.3 24x
I will be running a Holley, but I want my ac and factor gauges to work. I do have the factory computer.
wiil the 58 to 24 box work just for my ac and gauges ?
if went out that would be the only 2 things that would not work. The term will still run the engine.
is there a better way?
Old Feb 24, 2024 | 02:17 PM
  #112
robbieroflcopter's Avatar
Default Supercharger time
I'm looking at putting a twin screw on this setup now that I've got it running good. Looking at a Whipple. Obviously I don't think I can order it for the truck (2000 Silverado with 5.3l). So should I order a kit for a letter model year that had a 6.2 in it to make sure all the spacing works.
Old Nov 8, 2024 | 05:08 PM
  #113
Default Throttle pedal and throttle body
Time to switch to a different ECU for twin turbo setup to come. What electronic pedal and throttle body do I need? Gonna go holley or aces to run the engine.
​​​​QUOTE=robbieroflcopter;5527251]I'm looking at putting a twin screw on this setup now that I've got it running good. Looking at a Whipple. Obviously I don't think I can order it for the truck (2000 Silverado with 5.3l). So should I order a kit for a letter model year that had a 6.2 in it to make sure all the spacing works.[/QUOTE]
Old Nov 9, 2024 | 07:33 PM
  #114
RDF1's Avatar
DuNnO
5 Year Member
AC is easy, just wire it up so the holley controls it. Then use a holley output for a tach signal.
Old Nov 9, 2024 | 07:36 PM
  #115
RDF1's Avatar
DuNnO
5 Year Member
[/QUOTE]
You can use the truck TB and AP.
CP has several options to get your factory pedal to work.
https://currentperformance.com/produ...rottle-wiring/
Old Nov 9, 2024 | 07:52 PM
  #116
Default Dbc stock pedal/tb
Stock pedal is dbc. My computer (2000) won't run a dbw setup
I think a stock ls3 TB will work. Just wondering what pedal is going to be the easiest to get mounted when I pull the old one out.
I've been back and forth on the twin screw vs turbo setup. I'm thinking turbo for the cool factor lol. Need a project to keep me busy this winter.
https://currentperformance.com/produ...rottle-wiring/[/QUOTE]
Old Nov 9, 2024 | 08:04 PM
  #117
RDF1's Avatar
DuNnO
5 Year Member
You mentioned Electric throttle body and pedal. Was just showing you can use the truck DBW pedal with LS3 TB if you wanted.
BUt for turbo you can use the cable TB your using now.
I vote turbo. Its easy to adjust boost with Turbo. And dont have to worry about belt issues.
Old Nov 15, 2024 | 09:52 AM
  #118
Default Fuel injectors
Still working on getting all my parts sorted. Eventually I want to run E85 in the summers with my new setup. The injectors on the engine are 42# now. Based on the calculators I've seen I'll need to upgrade after I add boost. I realized that I have a set of stock 2020 GT500 injectors at the house. https://www.vmpperformance.com/Ford-...-KR3Z-9F593-AA lists these as 56# at 3bar (I run 4 bar fuel pressure so they'll be more). I think there's enough injector there but will they fit? It says they are stock EV6 length, which is what I have in the LS3 now I believe. The question is, can I just use an adapter to run them?
Zachariah Silvers
Feb 2, 2021 03:19 PM
Dakota LS Swap
Dec 15, 2017 09:32 PM
XLR8NSS
Jul 24, 2005 01:00 PM
jamesjones
Oct 14, 2004 01:45 PM
