Gauge Inaccuracy
Old May 29, 2005 | 11:37 AM
KySilverado's Avatar
Default Gauge Inaccuracy
Guys,
I recently installed a shift kit and had been tuning 1->2 shift with HPT. In doing so I was logging my Trans temp while driving. I installed a trans temp gauge in my cluster good while back. You have to pull the needles and put them back on. Good chance of error. Trans temp was way off to what HPT was telling me the temp was. Anyway got down to the cluster and decided to calibrate all the gauges to the PCM outputs via HPT. Got the tach real close, trans temp, oil pressure, etc.... The big suprise is how slow to respond and really inaccurate the temp gauge is to readings from HPT. Almost like they are reading in two different areas of the coolant flow. The gauge near the actual radiator side and the ECT temp from HPT on the engine? I just got it somewhere near close for an average temp and called it good.
Old May 29, 2005 | 07:40 PM
02sierraz71_5.3's Avatar
Originally Posted by KySilverado
Guys,
What the prosses for calibrating the guages with hp? Are these aftermarket or the guages in the dash? thanks
Old May 29, 2005 | 08:24 PM
Stock gauges. Just pull the indicators/pointers off and put them back on till they read with HPT.
Old May 29, 2005 | 09:42 PM
white1's Avatar
Yea I put in white gauges, and had to play with mine quite a bit to get them kind of close. Need to find someone with hpt to get them right.
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
