Gauge ?
Old Sep 18, 2005 | 09:11 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Question Gauge ?
Is there a gauge that measures IAT's or do I have to have logging software to see this? Something I can put in an A pillar?
EDIT:
Is this one or is it for something else?
Old Sep 19, 2005 | 09:53 AM
thunder550's Avatar
High on diesel fumes
it goes to 300*???
Old Sep 19, 2005 | 12:31 PM
vanillagorilla's Avatar
www.aeroforcetech.com
Check this gauge out, it pretty much does it all.
Old Sep 19, 2005 | 01:20 PM
TG02Z71's Avatar
Originally Posted by thunder550
it goes to 300*???
Must be for Jet cars or something!!!
Old Sep 19, 2005 | 05:02 PM
1SlowHoe's Avatar
Thats a pretty gauge. 220 isn't bad for everything it does. Put 3 of those in a pillar and it's like have 6 gauges that can all be changed to whatever you need to know at that time. Hmmmmm.
Old Sep 19, 2005 | 05:11 PM
1SlowHoe's Avatar
it goes to 300*???
The reason it goes up to 300 is to let you know when it's time to build a 408, because you just blew your engine.
Old Sep 19, 2005 | 06:44 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
That is the correct gauge.
Old Sep 19, 2005 | 08:36 PM
Mr. Sandog's Avatar
Only if you could splice together 3 cables in parallel....that gauge plugs directly into your OBDII port.
Old Sep 19, 2005 | 08:54 PM
1SlowHoe's Avatar
I emailed the company to ask how you can run them in series. Maybe there is an adapter or something....I'll post the response if I get one.
Old Sep 19, 2005 | 10:49 PM
They make dual setups and triple setups. They have a pn for the double gauges, but I think the triples are special order. It's under 400 for the double too. Just remember it won't display boost, because it still relies on your factory MAP sensor's range.
