gas pedal sticking?
no, don't try running it without the intake tube in place, you need to draw the air accross the MAFS or it either won't run or will throw and engine code... or if you are having a bad day it might do both
take the throttle body off and clean it. there are only 3 nuts holding it on and the throttle linkage and 2 electrical connectors. It is a good time to incorporate the throttle body bypass
. The gasket for the throttle body is like an o-ring. Can be taken on and off 100 times with no problems.
With the throttle body completely removed you can use a tooth brush and get everything spotless. I personally use 3M throttle body cleaner. I stay away from carb cleaner, there is a teflon coating on the throttle blade that most carb cleaners will remove. The throttle body cleaner is specifically designed not to remove the coating.
With the throttle body removed it is much easier to work with. I usually do it once a year at least.
. The gasket for the throttle body is like an o-ring. Can be taken on and off 100 times with no problems.With the throttle body completely removed you can use a tooth brush and get everything spotless. I personally use 3M throttle body cleaner. I stay away from carb cleaner, there is a teflon coating on the throttle blade that most carb cleaners will remove. The throttle body cleaner is specifically designed not to remove the coating.
